Old 01-03-2015, 08:53 PM   #11
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
We installed 4 GC batteries in our 13 36CKTS. Have had no issues, but I do the PM semi annually & check batt fluid level quarterly, and add distilled water only when indicated. Did add battery tender charger/maintainer which gets plugged in when the Creek is considered in storage, about 3-4 months each year!
Travel safe, enjoy the journeys & hope to meet at the FROG Int'l Ralley in August 2015 (Elkhart County Fairgrounds, Goshen, IN)
from iPad
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 01-04-2015, 08:58 AM   #12
CCRVOC
Ramblin Recks's Avatar
I just finished the installation of four batteries in the front basement. I welded 2 inch angle iron to the frame, and bolted down three-quarter inch plywood. welded the battery hold-down brackets to strap steel and bolted it to the plywood. added a drain that goes through the floor . used a container box from Lowe's with a vent mounted to the top. pictures will follow in a few days. Sorry for the format....
Yes. Looking forward to Goshen !
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 01-04-2015, 09:01 AM   #13
Battery
Here is pic of my setup. I also wired the batteries using 4/0 cable for an inverter
palmetto rogue is offline   Reply With Quote
Old 01-04-2015, 08:05 PM   #14
CCRVOC
Here are some pix. Battery wires, shunt and wiring will change/move when I install the inverter.
Name:	Chreeker Mods  2015_1120.jpg
ID:	68159   Click image for larger version
Name:	Chreeker Mods  2015_1121.jpg
ID:	68160   Click image for larger version
Name:	Chreeker Mods  2015_1118.jpg
ID:	68161   Click image for larger version
Name:	Chreeker Mods  2015_1119.jpg
led, battery
