Old 07-26-2016, 01:17 PM   #1
DDC
DDC's Avatar
Why the missing wet shackle?
Had a little spare time and was looking under the trailer on the shade side just for something to do, i decided to look at the grease fittings on the shackles to see how accessible they were, anyway I noticed that on the most active part on this type of suspension there is just a bolt, no lube ability at all. Anyone know any reason for this?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-26-2016, 01:25 PM   #2
TURBS's Avatar
Don, it's hard to tell but it appears you have grease fittings on the bolts.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-26-2016, 01:30 PM   #3
None on the center beam bolt where it is needed.
Old 07-26-2016, 03:09 PM   #4
I found 2 fittings inside of mine...if you look at your pic you can just see the tip of the zerk to the left of the bolt you are talking about
birdman77 is offline   Reply With Quote
Old 07-26-2016, 03:19 PM   #5
DDC
DDC's Avatar
There is no grease fitting on the equalizer bolt which is the most active part in this suspension.
Old 07-26-2016, 03:29 PM   #6
I will try to get a picture tonight...if I look inside the bracket welded to the frame I see 2 fittings that service that bolt...if I understand you correctly that is...if not I apologize in advance
Old 07-26-2016, 04:36 PM   #7
Old Member
Attachment 115352
That is because there is a bushing that is held in place and does not turn around the bolt. If you look up in the shackle you well see there are 2 grease nipples. One on each half of the equalizer
Cool Canuck is offline   Reply With Quote
Old 07-26-2016, 08:52 PM   #8
DDC
DDC's Avatar
I see them, thanks I did not look any farther than the end of the bolt-head.
Old 07-27-2016, 12:15 AM   #9
Old Member
Actually I fibbed a bit. There is no single bushing. The bolt goes through the 2 parts of the equalizer. The bolt is designed not to turn. The bushing material is on the equalizer parts and rotates around the bolt..
Old 07-27-2016, 06:16 PM   #10
Looks like the spring eye on the right is almost hitting the frame.
Elcheapo is offline   Reply With Quote
« New RVers | 35ik »
