Old 06-17-2013, 09:04 AM   #1
gkeager's Avatar
Unhappy Window woes
Is anybody else having trouble with their windows in the end of the slides? Ours are so hard to put up and down its coming to the point where we've quit using them at all. We're getting tired of the sore fingers, broken nails and cursing every time we attempt to use them. Any suggestion? Thanks.
Gerry & Kathy Eager
2013 Silverback 29RE
2005 Silverado 2500HD
w/Duramax & Allison Trans
gkeager is offline   Reply With Quote
Old 06-17-2013, 09:10 AM   #2
The windows on either side of our bed in our bedroom slide were hard to operate. Try spraying a small of silicone lube on a rag and rubbing it on the vertical channels where the window slides up & down. Of course you're going to have to have the windows up but hopefully it'll be the last time you have to fight them. You're probably going to have to slide the windows up & down a couple times to spread out the lube but it should get easier each time.
Old 06-17-2013, 07:30 PM   #3
rattleNsmoke's Avatar
X2 on the silicone spray.
rattleNsmoke is offline   Reply With Quote
Old 06-18-2013, 03:08 PM   #4
Only the first couple of times - seem to work for us fine now. Even to the point they will slam down if I let go of it.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
