Old 04-15-2016, 10:33 PM   #1
Winegard G2 Plus Satellite Dish
Has anyone tried hooking up a Winegard G2 Plus to the satellite cabling in the water closet connections. I purchased one today and works fine when using just the 25 foot cable provided to the Winegard power inverter. When hooking up the 25 foot cable to the satellite connection it does not work. I know the wiring s good because it worked with my older Winegard satellite dish. I am thinking the voltage they are putting on the line is too weak once it makes it to the basement connection. Just wondering if anyone has the new G2 plus.
Tom
2016 Ford Power Stroke F350 Lariat Crew Cab Long Bed Dual Wheel
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 04-16-2016, 08:23 AM   #2
Well got this fixed. Mounted the power inverter in the basement and connected at the wall of the water basement. With this being just as it exits the RV to the antenna it now works. Problem resolved but there is no mention in the manual how to resolve so those purchasing this model may want to keep this in mind.
Old 10-01-2016, 02:06 PM   #3
Setup to install winegard g2 plus
Sounds like got it installed and working. Can you explain how you got from basement satellite plug in and 110 into the water area of the RV. Also after wiring the inserter in basement is the direct tv receiver hooked in the living room to main tv or in basement with th inserter?
rew4hawks is offline   Reply With Quote
Old 10-01-2016, 02:37 PM   #4
The dish 211 receiver is in the living room next to the tv. The part I am talking about is the box which injects power on the cable line so you have one connection to the dish and drives the automatic satellite finding. There appears to be a footage limitation on the distance the box can send to the dish.
Old 10-05-2016, 04:23 PM   #5
SilverbackMel's Avatar
Are these things not a PITA, royally!!
One my biggest aggravations in RV'ing is this DISH crap.
I have 2; 211Z's. Can NEVER get bedroom tv to connect properly.
I have the Pathways x2. Tv in main cabin works fine. Yes, I do select 2 TV's in the beginning search mode.
SilverbackMel is offline   Reply With Quote
Old 01-22-2017, 05:04 PM   #6
My dealer installed the Wingard Traveler on my new 38EL. He used the presided coax in the roof and fished controller wire via roof to closet at front door.
Sent from my XT1254 using Forest River Forums mobile app
Cumminz is offline   Reply With Quote
Old 01-22-2017, 05:15 PM   #7
normally these portable type units can NOT be run through the coach's SAT INput since most RVs have at least one coax inline splitter, if not more, in the run of wiring - which causes problems with Satellite antenna signals. Running direct from the receiver to the Antenna with your coax cable is best, and I have run over 250' before with RG6 coax with no problems...
The Turners...
formerFR is offline   Reply With Quote
Old 01-22-2017, 05:21 PM   #8
My receiver does run straight to the dish on the roof.
satellite, winegard
