Old 03-21-2019, 10:18 PM   #1
hillsvillehokie's Avatar
Winterized ? Yeah right
So I had my brand new cedar creek fifth wheel winterized by the dealership I bought it from this past October. I go to drain the anti freeze and open up my fresh water valve just for the heck of it and water drains out at a steady flow for about 10 minutes!! I checked the best I could for any possible leaks from the tank and drain line, but no leaks appeared.
Question #1- what are the chances I dodged a bullet and nothing cracked?
Question #2- If I did dodge a bullet, how was that possible?
hillsvillehokie is offline   Reply With Quote
Old 03-21-2019, 10:30 PM   #2
SailorSam20500's Avatar
You're talking about the drain for the FW tank???
If yes, I'm not surprised.
10 minutes of draining indicates the tank was no where near full. Tank had lots of room for ice to expand.
Only thing that could have been damaged is the short section of pipe from the tank to the drain valve and the valve itself.
Similarly, leaving small amounts of water in the grey or black tank shouldn't be an issue. Also, unless you use a vacuum, you never get all the water out of the water heater.
If you are talking about the water lines to sinks, etc., I would check everything very carefully with system filled and pressurized.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 03-21-2019, 10:59 PM   #3
Thanks for the reply. Yes I was talking about the fresh water tank and the drain line.
Old 03-22-2019, 12:00 AM   #4
bikendan's Avatar
No need to put antifreeze in the FW tank, as long as it's been drained.
You don't want RV antifreeze in your FW tank.
Equalizer WDH
Old 03-22-2019, 04:57 AM   #5
Thatís my concern. It wasnít drained all the way.
Old 03-22-2019, 07:40 AM   #6
Possible they just forgot the FW tank. More likely they didn't have the unit level when they drained it. Knowing as long as a majority of the water being gone is good they may not worry about getting all the water out of the FW tank.
Cabinfever97 is offline   Reply With Quote
Old 03-22-2019, 07:49 AM   #7
bedubya's Avatar
SailorSam is right. Your fresh water tank is probably polypropylene (white translucent plastic) and has a lot of "give." To be certain you're OK, fill the tank. If there's no water dripping on the ground, it's all good.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 03-22-2019, 07:59 AM   #8
Thank you
Old 03-22-2019, 08:00 AM   #9
Fresh tanks are very forgiving to damage from ice freezing as there is usually plenty of room in them for the ice to expand and not break anything unless chocked completely full. As mentioned the drain line and whatever valve is on it to drain the tank can sometimes crack.
When whomever did the winterizing, they either forgot to drain the fresh tank or the rig was not level enough to where the tank didn't drain completely. I've seen both.
As mentioned, fill the tank completely and look for any sign of leaks (don't forget, the overflow will piss out when the tank is full so remember that) and if all is good, you are set to go.
If it were me, while filling the tank to check for leaks, I'd also add bleach to sanitize the system. Then once the system is sanitized, drain the bleach water and flush the tank and lines with fresh water. I always add Camco Drinking Water Freshener to my fresh tank when adding water.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 03-22-2019, 12:59 PM   #10
Capt. Mike's Avatar
The fact that you had enough water left to run out of the tank for 10 minutes tells me that the drain line and valve are OK. If it would have been cracked over the winter, whatever water was left in the tank would have run out as soon as it warmed up and the ice that cracked the valve had thawed. Next year, if you have the dealer winterize your unit again, when you get it home, open the fresh water drain just in case they left a little water in there again.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 03-22-2019, 04:23 PM   #11
Leaving water in the black or grey tanks is not good. It will settle in the low point which is the drain pipes and freeze, splitting the pipe before the valves. It is a job to replace those pipes. Don't ask me how I know.
TSman is offline   Reply With Quote
Old 03-22-2019, 04:35 PM   #12
Since your FW tank did not have any freeze damage at the drain it is very unlikely that any interior water lines suffered any freeze damage.
The drain cap/valve would be exposed to the coldest temps.
MtBiker is offline   Reply With Quote
Old 03-22-2019, 05:50 PM   #13
That is why it is a good idea to completely drain both. Then when winterizing run a little extra antifreeze through lines and toilet. I try and.put a gallon in both tanks.
Old 03-22-2019, 06:05 PM   #14
Movement always makes my camper drip more. I can leave the gate valves open for days. If I tow down the road and reopen more water always comes out. May not be bad as you think.
Kimber45 is offline   Reply With Quote
Old 03-22-2019, 07:21 PM   #15
I'd also be concerned about the line between the fence tank and the pump. I always blow air from the pump back to the FW tank. I would suggest that you consider winterizing your 5th wheel your self. Even if you don't think you have that capability for that job, it is not difficult to learn and you will get plenty if help from this Forum or YouTube. You will sleep better next spring when it's time to wake up your unit.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 03-22-2019, 07:23 PM   #16
fence tank=fresh water tank.
Cathy & Jeff
Midland, Michigan
Old 03-22-2019, 07:48 PM   #17
Me either!
Don't ask me either! Now I leave the gray water valve open all winter, draining into a Blueboy.
Larry
Larry-NC is offline   Reply With Quote
Old 03-22-2019, 08:46 PM   #18
The drain line from the fresh water tank is probably pex lines and it will expand some. Maybe it didnít get cold for to long.
spock123 is offline   Reply With Quote
Old 03-22-2019, 10:14 PM   #19
Thank you all for the great responses. Yes I think if I have learned anything from this is to just winterize it myself.
Old 03-23-2019, 09:06 PM   #20
HerveVR's Avatar
Good decision to do it yourself the right way.
Read post on forum, look at videos on Youtube, get yourself this kit:
https://www.amazon.com/Camco-Permane.../dp/B0006JJ588
follow the instruction to install.
Remember... Never, never put antifreeze in FW reservoir.
Pink antifreeze goes in the water lines behind the water pump, but the Water Heater that has to be bypassed. Put some in drain traps and Black and Grey tanks.
It's so easy and the investment will be recovered the very first year compare to the cost charged by an RV Box.
2012 Lexington 265DS
HerveVR is offline   Reply With Quote
winter, winterize
