Old 09-09-2013, 07:00 AM   #1
KKranec's Avatar
Winterizing laundry water lines
I have a Cedar Creek 36CKTS, soon I will be winterizing and wondering what I have to do with the laundry water lines?
KKranec is offline   Reply With Quote
Old 09-09-2013, 07:03 AM   #2
5erDriver's Avatar
Hi, either connect a laundry hose and use a bucket or use a small container right up to the faucets and draw the antifreeze thru just as you would for your sinks etc.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 09-09-2013, 07:07 AM   #3
Former Full Timer
Duckogram's Avatar
If you disconnect the lines to the Washer and open the valves, they will drain when you open the low point valve. You could pump pink stuff through the lines to address the water in the Washer pump as well.
OR
You can do what I did. Move to Flawda. LOL
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 09-09-2013, 08:13 AM   #4
rattleNsmoke's Avatar
When you run the pink stuff thru the lines, simply run your washer under a VERY SHORT cycle. If you have a Splendide combo unit, see here:
http://www.splendide.com/WD2_AW122_Winterize.pdf
rattleNsmoke is offline   Reply With Quote
Old 09-09-2013, 08:20 AM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
WOW...hard to comprehend those words "Winterizing" in early September!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 09-09-2013, 09:47 AM   #6
Campingnut's Avatar
I can't wait till I retire and can relocate to somewhere warm and not have to winterize my trailer in Sept.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 09-09-2013, 10:44 AM   #7
X2. That's what we did at the end of last season and it worked perfectly.
Wiscampsin is online now   Reply With Quote
Old 09-09-2013, 09:29 PM   #8
X3
Did the same thing with a small container.
Since we don't plan on adding a washer/dryer I was considering removing the water lines or installing a cut off valve.
Has anyone done this?
sidney is offline   Reply With Quote
Old 09-10-2013, 08:13 AM   #9
Campingnut's Avatar
I disconected the water lines to the washer, very easy to do.
Tim and Bev
2015 F-350
Old 09-28-2013, 05:56 AM   #10
have a 38FL has any1 winterized there ice maker yet? what is the best way to do it?
wire1946 is offline   Reply With Quote
