Old 10-22-2014, 09:33 PM   #1
Hutch333id's Avatar
Winterizing the city water connection a 38fl
Hi all,
Has anyone got any experience they can share about how I winterize the city water supply connection? On my previous TT's I used to remove the mesh filter and press the small valve concealed behind. This used to result in the antifreeze spurting out of the connection and usually all over me. On the 38fl, I don't appear to have this set up. I've winterized the rest of the rig, just not the last part and I don't want to get caught out.
Thanks in anticipation.
Richard & Diane
2014 Cedar Creek 38FL
With a F350 dually
2014 41 nights and 4620km.......and we're done
Richard & Diane
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 10-23-2014, 06:51 AM   #2
I use air and one of these blowout plugs to purge the entire system of water before I put some antifreeze into the system. Oh and I will be installing a bypass on the filter housing to prevent that from taking a bunch of antifreeze.
http://www.amazon.com/Camco-36153-Br.../dp/B0006IX68O
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 10-25-2014, 09:00 AM   #3
38fl, interested in your bypass for the filter housing. We had a Salem in the past and I found a housing half the size of the normal housing the help reduce the amount of anti-freeze but now have a Cedar Creek. Looking for ideas as well regarding the water filter.
Rick & MindyBasehor, Ks
2009 Cedar Creek Custom
34SATS
ricker813 is offline   Reply With Quote
Old 10-29-2014, 09:46 PM   #4
SilverbackMel's Avatar
Water filter housing
On my 33RL, did HW heater bypass and pulled the filter and tossed it. Re-installed housing and let it fill as I pumped anti freeze through the system. Once completed, pulled the housing and used the anti freeze in it to pour down sink drains. Dried housing and screwed it back on. Can't freeze with nothing in it and dry Anti freeze remains in in/out lines on both sides of the filter system.
SilverbackMel is offline   Reply With Quote
water, water connection, winter, winterize
