Old 07-10-2019, 12:44 PM   #1
Wrench needed to retrack slides manually?
What kind of wrench should a person have on hand that can be used to retrack a slide if it fails to retrack hydraulically? I have a 2015 Cedar Creek Hathaway Edition 34RE.
rrolphe is offline   Reply With Quote
Old 07-10-2019, 01:54 PM   #2
DaGrinch's Avatar
I guess it would be good to know what type of slide you are talking about. A hydraulic slide? Picture (s) of the carriage perhaps?
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 07-10-2019, 01:57 PM   #3
Smile Wrench needed to retrack slides manually?
Thank you for your reply. The slides are hydrallic. I called Forest River and the kind sales manager sent me a photo of where to find the motor.
Old 07-10-2019, 01:58 PM   #4
PPST Wannabe
kenandterry's Avatar
The op already said “hydraulically”.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-10-2019, 02:31 PM   #5
DaGrinch's Avatar
Yep, you're right, he did and that's why I reiterated that in my reply. I hadn't seen hydraulic slides before, therefore my request for a picture or 2. I've dealt with other types, but not hydraulic.
Old 07-10-2019, 11:19 PM   #6
dieselguy's Avatar
You'll need a 1/4" hex bit and a battery operated drill that reverses. One direction runs the slides out the other direction brings the slides in. You'll also have to find the slide out solenoid and using a 1/8" allen wrench turn the set screw in the solenoid clockwise to manually open the valve. Be sure to close the solenoid set screw when done manually moving the slide(s). The drill and hex bit fits in the end of the hydraulic motor under the label that says manual drive access. This is a generic work sheet showing what you'll be looking for. http://www.rvupgradestore.com/v/vspf...s/pdf/0071.pdf
dieselguy is offline   Reply With Quote
Old 07-11-2019, 07:48 AM   #7
x2...however, we found that for our Silverback 33iK we found that our battery operated drill wasn't strong enough to pull the hydraulic slide in. We had to use the electric drill. The battery drill wasn't high speed enough.
Thanks for the link to the directions, dieselguy. Good info.
2019 Forest River Silverback 33iK
Ford F350 tow vehicle
SW Pennsylvania
Member Travel Resorts of America
Retired and adventurous!
Bbfish is offline   Reply With Quote
manual, slide
