Old 12-08-2015, 08:28 PM   #1
wls
zone 1 and 2
I see on the thermostat you can program zone 1 and 2. My question is how does the air conditioner know what zone it is in, if the 2 air conditioners are mounted on a race track duct work, how does it know where not to dump so much cool air.Just wondering.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 12-08-2015, 09:10 PM   #2
Both units dump into the same plenum. If zone 2 is on then it feeds the entire plenum from the second air over the bedroom. Same goes for zone 1. There is no blocking of air for the zones.
ttanous is offline   Reply With Quote
Old 12-08-2015, 11:32 PM   #3
elrand's Avatar
Zone 1 is the main room zone 2 is the bedroom. Even though it's 1 plenum. You have 2 temp sensors zone 1 is in your thermostat zone 2 is mounted on the ceiling of your bedroom. That way each area gets a temp with some bleed over to the other
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
Old 12-09-2015, 07:06 AM   #4
wls
ok, thanks guys
Old 12-09-2015, 01:29 PM   #5
Jim34RL's Avatar
I think the newer 2016 models may have the temp sensor on the wall next to the light switch now. I saw a photo of a 34RE at a dealer with the sensor on the wall. The unit also had the extra heater for the bedroom in it.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 117K+miles
Old 12-09-2015, 02:36 PM   #6
wls
I have zone 2 sensor up in the bedroom, and I also have the built in heater in the bedroom, not sure where the sensor is located in the living area, will look tonight.
Old 12-09-2015, 03:07 PM   #7
dieselguy's Avatar
Living area sensor is part of the wall thermostat. Yes, the mid year models have the bedroom sensor on the wall instead of the ceiling.
dieselguy is offline   Reply With Quote
Old 12-09-2015, 03:28 PM   #8
Probably put sensor on the wall due to adding heat to bedroom...
2016 Siverback 33IK
Old 12-09-2015, 04:37 PM   #9
dieselguy's Avatar
I think they placed it on the wall to possibly follow SOB lead and give a better location for feedback. Sensor on ceiling seemed always in the path of cold air right off the vent.
