Old 10-15-2013, 08:53 AM   #1
Mabovero's Avatar
19CB Hot Water Heater Drain?
Regarding Coachmen Freelander 19CB
Can anyone tell me:
1) Where the hot water heater is located, and,
2) How to drain it?
Thanks I advance!
Michele
Mabovero is offline   Reply With Quote
Old 10-15-2013, 09:17 AM   #2
wmtire's Avatar
Michele, If this is your RV, the water heater is behind the outside access panel, I have the red arrow pointing to.
To drain it, if it's a Suburban brand, you remove the anode rod at the bottom front of the unit. It requires a 1 and 1/16th inch socket to remove it. I included the link below that also has a chart so you can inspect the anode rod while you have it removed, draining the tank. You have to replace these rods as needed on the Suburban brand heaters, and is a regular maintenance item.
Drain the hot water heater?
If it's an Atwood brand, there is a drain plug (plastic) on the bottom front.
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 10-15-2013, 09:28 AM   #3
wmtire's Avatar
Michele, if you do have the Suburban brand water heater, you may find this useful too, if applicable:
http://www.forestriverforums.com/for...ore-36197.html
Old 10-15-2013, 12:30 PM   #4
Mabovero's Avatar
Thank you
Thank you so much for your help!
