Old 06-03-2014, 03:12 PM   #1
2014 Encounter propane leak
Had RV for one day and had to go back for multiple issues. While back at dealer I told them I smelled propane and asked them to check for leaks. They told me it was fine. I'm assuming they never opened the valve because as soon as I opened it this past weekend on a trip I could hear it and smell it leaking. I took the plastic cover off of the regulator and found that it is coming out of a vent on the regulator. Anyone know why that is? I've attached a picture pointing to where the propane is leaking from, so hopefully someone will be able to chime in. Waiting for response from dealer.
Name:	ImageUploadedByForest River Forums1401826327.899277.jpg
TangoTango is offline   Reply With Quote
Old 06-04-2014, 06:19 AM   #2
CSMRetired's Avatar
Similar situation on ours
simple answer......replace the regulator, sooner the better!
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 06-05-2014, 01:39 PM   #3
Would you believe that the dealer doesn't have ONE in stock? When they receive one, this will be my third trip back in about a month. Brand new unit.
Old 06-05-2014, 04:11 PM   #4
The leak is from a ruptured diaphragm. The diaphragm has propane on one side and is vented to the atmosphere on the other side.
RamblerGuy is offline   Reply With Quote
Old 08-03-2014, 10:54 AM   #5
CSM asked for fill up the next time you go. They will do it. But you got to asked
windspade1 is offline   Reply With Quote
Old 08-03-2014, 03:38 PM   #6
CSMRetired's Avatar
Thanks for the info
'Pa Pa's Palace'
2014, leak, propane
