07-01-2015, 02:37 PM
#41
You're forgetting that you didn't burn any gas in the Toad. If it got 20 mpg, and you drove it separately, you'd use ten additional gallons. So factor that into your overall mileage.
2013 Mirada 29SE, I earned it!
07-01-2015, 03:04 PM
#42
I'm going to camp whatever it costs...
but I do admit to staring at the gas mileage since they have it computing constantly right there on the speedo....
It's hypnotising.
2015 nights camped (54)
07-04-2015, 06:58 PM
#43
Commercial Member
Originally Posted by Stinkielee
1st trip of 187 total miles, mixed terrain, towing a 2000 lb toad. We were SHOCKED. It was a 3 day stay at Pinnacles National Park. This information may put a serious crimp in our dream.
Give the engine and coach 500 miles to "brake-in" At 28,334 mi our 2008 Coachmen 2130QB on Chevy chassis delivered a TOTAL mpg of 10.8.
Now there are a lot of variables but the primary one is the driver's right foot. Your RV will not accelerate as quickly as you are use to in your car or P/U. What is the inflation of your tires vs the real measured load on the tires. Based on Load infl tables I am running with an 18 to 21% margin or excess capability.
I also use a ScanGauge to keep an eye on engine Load and try and keep it under 80%. Going up hills I watch and shut the cruse off at 98% load before it downshifts.
It takes an active driver paying attention to achieve this mpg but it isn't too hard. I also set cruse on flat roads at 60 to 62.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
07-04-2015, 07:38 PM
#44
Director, FROG
Originally Posted by CSMRetired
I do it this way
Insert the nozzle in the tank
Set the trigger
Wait for the trigger to click and shut off
Pull the nozzle from the tank and hang it up
Cap the tank and move out
Just don't look at the pump
Dennis, I don't see a step labeled "Pay for Fuel." You can save a ton of money by leaving that one out.
07-04-2015, 07:42 PM
#45
Director, FROG
Originally Posted by Roll
So Poppy....
Gas has a "price" based (I thought) on material and manufacturing costs plus profit. Why doesn't that price follow the gas to the pump?
Why do we pay the current market price for gasoline that has likely been in storage for months and may have an actual price substantially more or less than current market prices?
Just curious.
Gary
Gary, you're essentially paying what it's going to cost the gas company to replenish its supply. It's exactly the same as what you're doing now when you fill your tank. You have to pay to fill your tank at current prices, and the wholesaler/refiner has to pay to fill its substantially larger tanks at current prices as well.
07-05-2015, 10:23 AM
#46
Now I have been busted!
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
07-10-2015, 07:12 PM
#47
Back on topic!
I didn't read all the pages, but his sig and pic shows a 22ft class C,. With that your mileage should be around the high 8's to low 9's. Maybe adjust your driving style? It takes a bit getting used to something like this, they don't drive like a car! Were you running the generator? That will kill mileage. I wouldn't sweat 7.5 mpg. Your essentially moving a house around the U.S. Along with a car. For the views we are capable of and the areas we can get to it is well worth it!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
07-10-2015, 08:57 PM
#48
Better mileage; travel light. If you don't need fresh water while traveling, only carry enough to travel. (water is 8 lb per gallon). dump black and grey before traveling.
Lower speed, we hang around 62-65. Slower speeds going up mountains, slow down, drop a gear or two on the tranny, and fall in line with the 18 wheelers.
If you are close to the border (AZ, NV, OR) plan your fuel so you purchase fuel in those states.
We travel through Calif a lot, we always make sure the tank is full before we cross into CA. If we need to buy fuel in CA, we buy only enough to get us out of CA, then fill up when we get into the surrounding states.
We consistently average 8.2 MPG. 30Ft Mirada with a Honda Civic TOAD.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
07-11-2015, 10:42 AM
#49
Originally Posted by OldCoot
And I thought all political bs and govt bashing was not allowed.
Moderators must be napping.
We are looking at it now. This one is going to need some cleaning up as it is severely leading off topic and into an area that has historically proven to get members dander up....which is why we NEED this guideline:
- General discussions of politics, general government policies, weaponry, gun rights and religion are not allowed in ANY areas of the forum. Discussions about current or pending legislation or regulations, weapons and religion that directly pertain to RVing are acceptable but will be closed or removed if they wander off topic or become disruptive.
Please post responsibly. We are all friends here.
The site team is going to close this thread while we clean it up.
2011 Flagstaff 831 RLBSS
09-20-2015, 04:27 PM
#50
Your engine isn't broken in until around 1,000 miles. It should get better.
09-20-2015, 04:42 PM
#51
Vietnam Veteran
In Hutchinson Ks today,,,$1.99 a gallon
Phil
2014 Ram 1500 5.7 Hemi 3.90gear
2015 Rockwood 2604WS
09-20-2015, 04:45 PM
#52
I get 9.6 mpg without a tow. Like someone once told me [ If you have to worry about the price of fuel maybe you need another hobby ]
09-20-2015, 06:13 PM
#53
I am enjoying under $3 a gallon. Even in Reno. I pray they get lots of moisture out here this winter. Lakes are so down.
Don - Anita Rateike
5th wheel 8528RKWS
2015 Chevy 2500
2414 Blue Ridge Drive
Greenwood, In 46143
09-20-2015, 06:22 PM
#54
3.25 in Vegas for mid-grade and 2.69 for diesel.
Happy to see diesel lower for all you big boys but by the time I upgrade I'm sure it will be through the roof again! Good thing for you guys that I'm not upgrading for a while!
Just glad to get away
09-20-2015, 07:15 PM
#55
$197.00 at BJ's today in Clermont Fl. and a dime cheaper if you have there Perks credit card
09-20-2015, 07:25 PM
#56
Pardon me?
Why ya'll so up on that price?
09-20-2015, 07:42 PM
#57
Because it's really a great time to own an RV with the price of fuel about a dollar a gallon less than last year and still going down.
09-25-2015, 12:19 PM
#58
travels to North carolina
we ran on to gas prices in Arkansas to the tune of 1.86, sure feels good to fill up for less than a hundred dollars
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
09-25-2015, 10:46 PM
#59
Dahagen
My brother took a trip to Peru that lasted 3 weeks. Cost him $7000. I traveled from Phoenix to El Paso, San Antonio, New Orleans, Florida panhandle, St. Augustine, Savannah, Nashville, Memphis, Denver, and everything in between ending in Idaho on a 5 month trip. Cost $7000 and that included gas, camping, tours, dining, etc. I wonder who had the most fun? Take your time traveling in an RV and it really is not that expensive, all things considered.
09-26-2015, 10:09 AM
#60
That would be some trip!
Idaho is a great place to end up in.
