Old 06-09-2016, 03:51 PM   #11
Originally Posted by Stormrider151 View Post
Usually they are in the bathroom or around any wet area. It would be unusual but maybe an outside receptacle. When I built my teardrop I used GFI breakers.
Never thought of outside. Will check it tomorrow.
JimNichols is offline   Reply With Quote
Old 06-09-2016, 04:19 PM   #12
fonzie's Avatar
Are you able to plug in shore power to check if all ac works?
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 06-10-2016, 12:49 AM   #13
bob dirt's Avatar
It's not a GFI problem. A/C, microwave and TV won't be connected to one. Check the 120 volt breaker at your generator. Start at the source. If you have power there, go to the next common connection point which would be the panel where the breakers are attached.
2016 Forester 2401WS MBS
Life is the cookie
bob dirt is offline   Reply With Quote
Old 06-10-2016, 08:14 AM   #14
Power from the generator to the converter indicates that there's power to one side of the AC breaker box. A popped circuit breaker at the generator ir in the breaker box is one cause of this problem but no mention of the more probable cause has appeared.
From the initial description: "started generator - batteries charged ...." is an indication that the rig has an automatic transfer switch. If one side of the transfer switch failed, some AC devices would would have no power while others would work without problems. This sounds like exactly what's happened.
The inputs and outputs of the transfer switch should be checked. If there's no power at the input, a breaker at the generator or a broken wire between the generator and the transfer is the culprit unless the generator itself has failed, an unlikely occurrence. If there's power at the inputs and none at the outputs, it's the transfer switch; probably the contacts on the relay. If the outputs have power, then the problem lies between the transfer switch and the circuit breaker box, or in the circuit breaker box.
Circuit breakers do fail but it's a very unusual thing to happen in an RV because you rarely manually throw the breakers.
I am surprised that both air conditioners don't work though. They should be wired to different legs of the incoming power to the breaker box so I'd expect one of them to work if half of the transfer switch failed.
Whatever the problem is, it'll be easy to figure out with an AC voltmeter. There should be 120-130V between the neutral (white) and each leg of the power (red,black) wherever you check. Checking with both shore power and the generator will help isolate the problem. If you're not very comfortable working around 120VAC with meter probes, additional protection can be obtained by wearing a pair of insulatin protective gloves like the throwaway ones you use for handling the sewer hose.
Originally Posted by JimNichols View Post
2014 Coachmen Mirada 29DSSE.
Doing some maintenance today. Realized I had left the main power on a couple of weeks ago. In Texas. Hot. Started Vehicle. Started Onan 5.5 K Generator from drivers seat. No problem.Batteries charged in 15-20 minutes.
Interior Lights work. Both slides work. Refrigerator works on house power. Neither A/U Unit will start. Power to both thermostats. Microwave has no power nor does either TV.
Checked all 110v and 12v breakers and fuses.
pmsherman is offline   Reply With Quote
Old 06-13-2016, 05:08 AM   #15
Found the problem. Wire loose inside the 50 AMP receptacle (shore/generator wire). I was down to my last resort before taking it to the dealer.
Old 06-13-2016, 05:11 AM   #16
Bob & Donna
Good to hear. You just saved yourself some big bucks!
BobandDonna is offline   Reply With Quote
Old 06-13-2016, 07:44 AM   #17
SeaDog's Avatar
Thanks for letting us know what you found good job fixing it
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 06-13-2016, 01:54 PM   #18
Our Mirada did not have a transfer switch. Are you saying the box you plug your shore cable in to in the outside compartment had a loose wire in the receptacle?
Life is always better under a Palm tree...
2016 Mirada 35BH "Trolley"
2016 Jeep Cherokee Latitude
Previous- Jayco Greyhawk 31FK
Western NY
WDW is offline   Reply With Quote
Old 06-15-2016, 05:18 AM   #19
Also glad you found the problem.
However if anybody is using this thread as a resource for any future problems The response from PMsherman is in error in that 2 "legs" of a 120 volt circuit do not exist. They do exist in a 220 volt circuit. Maybe he is from Europe where I understand some campers are 220 volt.
KAttkisson is offline   Reply With Quote
Old 06-15-2016, 08:35 PM   #20
I am a new member, just found you all today and happy I did! PMSherman response was EXACTLY what I was dealing with today, brand new transfer switch, installed by dealer where we purchased our 2014 Coachmen Encounter 37TZ in April, failed. It had experienced some intermittent issues since we picked up our coach but was always able to get the AC units fired up affter a couple tries. But yesterday and today couldn't get either, or the microwave, or the TV's to come on. Back to the dealer we go on Friday for a new ATS!
rac912 is offline   Reply With Quote
