Old 06-08-2016, 09:55 PM   #1
A/C, Microwave, TV Not Working
2014 Coachmen Mirada 29DSSE.
Doing some maintenance today. Realized I had left the main power on a couple of weeks ago. In Texas. Hot. Started Vehicle. Started Onan 5.5 K Generator from drivers seat. No problem.Batteries charged in 15-20 minutes.
Interior Lights work. Both slides work. Refrigerator works on house power. Neither A/U Unit will start. Power to both thermostats. Microwave has no power nor does either TV.
Checked all 110v and 12v breakers and fuses.
HELP.
JimNichols is offline   Reply With Quote
Old 06-09-2016, 07:15 AM   #2
Bob & Donna
Did you turn on the house batteries?
BobandDonna is offline   Reply With Quote
Old 06-09-2016, 07:48 AM   #3
SeaDog's Avatar
The problem appears to be in the 110V system. I would recheck the circuit breakers actually turn off and on. When you say fridge works on house power do you mean 12V or 110V. Also check the circuit breakers on your onan I believe there are two by the circuit board. If you correct the problem be sure to let the forum know what you did.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-09-2016, 11:10 AM   #4
House Batteries turned on. Also checked them with meter.
Old 06-09-2016, 11:15 AM   #5
I have toggled all 110v breakers. Also pulled and checked 12v fuses. I pulled cover off onan but didn't see any breakers on or near it, only an on/off switch. Will check again.
Also, cussed a lot.
Thanks, Jim
Old 06-09-2016, 11:22 AM   #6
bob dirt's Avatar
You can't check breakers by looking at them. Check the terminal with a meter. It looks like you have no power at the main buss bar the breakers attach to. Check power with a meter where the main cord is plugged in.
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 06-09-2016, 01:45 PM   #7
Stormrider151's Avatar
GFI trip maybe?
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-09-2016, 02:02 PM   #8
GFI may be the answer, if I can find reset plug. Haven't found it yet. It is not at plug:
1. Below passenger seat.
2. Under table.
3. On slide in kitchen.
4. Near TV in kitchen.
5. Near bathroom sink.
Opening bedroom slide now.
Old 06-09-2016, 03:22 PM   #9
Usually they are in the bathroom or around any wet area. It would be unusual but maybe an outside receptacle. When I built my teardrop I used GFI breakers.
Old 06-09-2016, 03:36 PM   #10
Also you might check your generator for anything that may have tripped on start up.
