Old 07-04-2016, 05:40 PM   #1
AC
I have a new sportscoach cross country 404rb and need help on AC. The controller I have is a domestic, I have two zones. I have set both on auto and at 67 degrees. The master gets down right cold but the coach does not seem to. Middle of coach ceiling is big vent which all the openings wide open and when u stand under cold- but all other 9 round vents very little comes out. Cabin pleasant when coming in coach but after awhile not so. Been in Galveston 4 days and AC still on. Also drivers AC up front(like normal car etc) starts out cold when driving but later feels just like a fan. Someone said maybe AC unit bad or not sealed right. Just curious if anyone else having this problem
msbaker is offline   Reply With Quote
Old 07-04-2016, 06:03 PM   #2
The vents under the unit need to be closed to force the air out the vents.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-04-2016, 07:10 PM   #3
I will try that. Thanks
Old 07-12-2016, 12:05 PM   #4
Land of the Midnightsun
jjSpeedwagon's Avatar
Our ac has that big vent. It's called ac dump and is used for faster cool down then when you get close to your temp setting shut vent and use your ceiling vents
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 07-12-2016, 12:07 PM   #5
TURBS's Avatar
AC
Also with the dual zone thermostat you want to set it on cool as auto is heat and cool depending on the temperature.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-12-2016, 02:58 PM   #6
Thank u. Getting it looked at next week anyway. Did not realize to put on cool rather than auto. I did what u said the last night we were there. I was told by coachman that it past they had trouble with AC. They told me that I should look at round vents furthest to front put fingers in forward and c if they blocked AC from going further front cause it would end up in ceiling. I did not feel blockage. The other problem was the coach drivers air would start cold then warm like out of freon, getting looked at next week. Thanks
