Old 08-03-2016, 08:03 AM   #1
AC running at only 1 speed, compressor not coming on
HI all,
We are on a road trip and this happened once before on the trip. The AC has only 1 fan speed, low, and there is very little air coming out. The compressor is not coming on. This happened once before on this trip when we tripped the GFI switch in the bathroom with the hair dryer. After we figured that out and reset the GFI the AC was normal again. But this time the AC did the power down thing in the middle of the night - no GFI trip. Any ideas?
gja1000 is offline   Reply With Quote
Old 08-03-2016, 08:28 AM   #2
TURBS's Avatar
Was it froze up?
I've never seen only one fan speed.
It would be best if you give year make and model of camper when asking information as we have no idea what you have.
Make and model of a/c would be great to since there's many a/c units .
Any answers will be guessing .
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
Old 08-03-2016, 09:24 AM   #3
Originally Posted by TURBS View Post
Was it froze up?
2015 Columbus 320RS
2008 2500HD Duramax
Domestic AC in a 2015 Coachman Freelander
Old 08-03-2016, 11:05 AM   #4
Head Rambler
Sounds like the thermostat or control board is going bad.
Since it's a 2015 model I assume that you have the digital thermostat?
Do you have two air conditioners?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-03-2016, 11:33 AM   #5
Flybob's Avatar
Originally Posted by gja1000 View Post
HI all,
If the GFCI did trip and the AC was on that circuit, you would have no fan and no air coming out. Also usually the AC is on a separate GFCI. What is the thermostat fan speed set at?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-03-2016, 03:31 PM   #6
A/C
Happened to me 2 months ago in South Fl. 93 degrees and all that was running was the fan. Went to a hotel that night and drove home to Central Fl next morning and dropped RV off at the dealers next morning for a new A/C
poppytoymaker is offline   Reply With Quote
Old 08-20-2016, 07:47 AM   #7
Check GFCI again
If resetting the GFCI worked the first time, I would reset it again. Also, a lot of motors shut off automatically when they overheat. It may cool down and start to work again.
mnoland30 is offline   Reply With Quote
