Old 08-26-2014, 10:43 PM   #51
USN/LAPD (Retired)
Safari-Rick's Avatar
Hey, at least he's alive to talk about it ! Not to mention pouring in mucho mucho gallons of bleach and ruining plumbing !
Better to have more then you need in case you don't have enough, because you can't get more !
Safari-Rick is offline   Reply With Quote
Old 08-27-2014, 06:06 AM   #52
TURBS's Avatar
Originally Posted by Hugh R View Post
So I did the water:bleach thing. I used a short hose to the tank fill with a funnel, diluted the bleach with water and poured it in. It took forever. Too much back pressure I guess with all the fittings, like 1/2 hour to get it all in. Ran the pump, faucets, shower and toilet until I smelled chlorine. Next time I think I'll buy a drill motor water pump from HD and push it in. I'll flush it in the AM. Nice point someone earlier made about running white vinegar through if it still smells like chlorine.
One thing you CAN'T do is turn your garden hose on full and try to fill your fw tank!
Air cannot escape faster then water being put in.
It's also not good for your fw tank to do so!
Try just turning on your hose at at half or less.
1" hose Inlet
1/2" air outlet
Try turning your hose on at a trickle the slow turn it up a little until you find a good ratio and it's not spitting back at you.
TURBS
"SABRE OWNERS UNITED"
tank, water, water tank
