Originally Posted by aceinspp
Well when we see the fire in the camp ground and it is a rv guess the filter may have cause it. Good luck on the install. As said if it was meant to have one the manufacture would have provided it. Later RJD
Won't be my unit burning up. Most RV fires I have seen were due to fridges or electrical issues. Putting a light filter on the furnace IS NOT going to cause overheating or a fire. Based on your "manufacturer provided theory" I guess I don't need a EMS/Surge protector or water pressure regulator either.
Both of which I use. I have seen what happens in both cases. Interestingly enough there are quite a few manufacturers that do provide both, but they are on the higher end, more expensive units.
Aaron
