Old 03-24-2016, 06:00 PM   #21
Oakman's Avatar
Here’s a quote from page 16 of my Suburban furnace owners’ manual.
Return Air - The cabinet that the furnace may be installed in will have louvers or openings for the return air back to the furnace. When the furnace is installed, it is imperative that the return air louvers on the furnace cabinet opening are not obstructed.
Insufficient return air will cause the furnace to overheat and cycle on limit.”
Whether or not you install a filter is no skin off my nose. For all I know you might have a completely different RV furnace than what I have. I’m just suggesting that folks read the manuals that come with the appliances.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-24-2016, 06:21 PM   #22
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by wahoonc View Post
Yes I DID read the manual. The only thing is says is that it needs 80 square inches of return air space. It doesn't say jack about whether you can use a filter or not. I would much rather clean pet hair out of a filter than the freaking blower box. FWIW yes FR does build to a price point and buys less expensive things to keep the profits up and the costs down. Many of the appliances are built to specifications provided by the RV companies. They can ask for whatever they want and it will be provided at a price. Yes the appliance manufacturers build things and sell them to the RV assemblers. I have worked in a variety of industries and cost vs profits is a primary driver in just about everything.
Also I have taken apart my fair share of furnaces in houses as well as RV's and while there are some differences there are more similarities than not.
Aaron
Well when we see the fire in the camp ground and it is a rv guess the filter may have cause it. Good luck on the install. As said if it was meant to have one the manufacture would have provided it. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 03-25-2016, 06:15 AM   #23
World Wide Wanderer
wahoonc's Avatar
Won't be my unit burning up. Most RV fires I have seen were due to fridges or electrical issues. Putting a light filter on the furnace IS NOT going to cause overheating or a fire. Based on your "manufacturer provided theory" I guess I don't need a EMS/Surge protector or water pressure regulator either. Both of which I use. I have seen what happens in both cases. Interestingly enough there are quite a few manufacturers that do provide both, but they are on the higher end, more expensive units.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
furnace
