Old 03-28-2016, 11:42 PM   #1
add on inverter
I have a 2016 Coachman Prism on the Mercedes 3500 frame. In looking at the alternator it is 14 V 220 A - if I put a 3000 watt inverter and run the vehicle motor to charge the batteries while the inverter is running will this hurt anything? The Mercedes motor is way quiter than the Onan QD 3200.
Lee F is offline   Reply With Quote
Old 03-29-2016, 12:30 AM   #2
2012 Solera
I understand long periods of idling is problematic for the Mercedes Sprinter. Believe it can damage the Diesel Particulate Filter (and maybe other stuff).
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 03-29-2016, 12:33 PM   #3
extremebike's Avatar
Buy a inverter generator. It will be a lot cheaper than the repair to your diesel. You only need a small generator if it's just for charging batteries.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
inverter
