09-12-2016, 10:04 AM
Air bag pressure?
What do you all normally run your air bags at?
Thanks, Steve & Deb
2016 Coachman Concord 300DS-SOLD
2011 36QSH TIFFIN PHAETON
Garmin RV 660 MLT
2008 Jeep Sahara
-Blue Ox base plate | Ready Brute Elite
09-12-2016, 11:29 AM
65 psi in all four.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
09-12-2016, 06:40 PM
I saw a video made by a factor rep he stated 80psi
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
09-12-2016, 09:57 PM
BOBDAWG
Air pressure
Just got our 300TS 2 weeks ago, dealer told us 50 lbs. Drove to Missouri from Texas and had soft ride. Had much better ride than 2 previous class Cs we have had.
09-13-2016, 09:30 AM
Land of the Midnightsun
After I installed the safe t plus. I adjusted air a lot ( depends what you carry in Moho also ) but found 75lbs in bags and all tires. Seems to work best for us. High cross winds and big trucks blowin by the concord handles very well.
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
09-13-2016, 04:36 PM
I going to add a wireless air pump so I can check and fill anywhere. Sometimes I lose air pressure need to fill anywhere. I find if I run 80psi my back side dont drag...
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
09-13-2016, 05:16 PM
Wireless air pump?
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-13-2016, 05:26 PM
Yes the guys at the 4-wheel shop said they have a wireless pump. I will see if I can find the information on it. I scratch my head also but that what they said. Price is around 600 dollars.....
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
09-13-2016, 05:42 PM
I use bicycle pump to fill mine. Works pretty good
John & Janice
09-14-2016, 05:38 AM
09-14-2016, 09:39 AM
Originally Posted by Dr Safety
JJ reminded me about MY little Co2 bicycle pump. It should work great for the airbags and I already have it... just need to stock up on cartridges:
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
10-19-2016, 02:22 PM
I use a Sears 19.2 volt air inflater works well
10-25-2016, 06:35 AM
65 psi in mine. I arrived at this by trial and error, and 65 gave me the best ride.
10-25-2016, 08:00 AM
I just installed (a few weeks ago) the wireless one...
https://www.airliftcompany.com/produ...s/wirelessone/
Control is wireless and works great. I installed mine using a relay for power vs. their recommendation of connecting to a 15A fuse in the junction block. Installed Firestone Ride Rite bags, but used the Airlift compressor.
And if purchased before 10/31, there is a $75.00 rebate on the compressor system. (And Amazon is an authorized retailer for the rebate.)
https://www.airliftcompany.com/support/rebates/
11-04-2016, 09:20 AM
I went ahead and ordered the airlift 7200. I have air bags on concord already think this will work well. Thanks for heads up f5moab. Better than my bicycle pump lol
John & Janice
11-04-2016, 05:09 PM
70 lb.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
11-04-2016, 06:08 PM
I run 70lbs
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
11-04-2016, 07:59 PM
World Wide Wanderer
I have been running 60-70 pound range on mine. I haven't noticed a huge difference. I will run towards the higher side with I have extra water on board.
Still need to get the beast weighed.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2015 Fusion Hybrid following along
11-09-2016, 09:11 PM
50-60 lbs.
