Old 07-24-2016, 08:25 PM   #1
Tbonz's Avatar
Air compresser
What type of air compressor do you carry. I believe this one will fit nicely in a compartment..110PSI. I prefer a compressor over an inflator.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 07-24-2016, 08:28 PM   #2
Tbonz's Avatar
cabinet door struts
Also installed struts on the bedroom overhead cabinets..
Old 07-25-2016, 10:06 AM   #3
grumpy0374's Avatar
Sears Craftsman Airboss. Small, compact, 110 volt, powerful.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 07-28-2016, 06:01 PM   #4
World Wide Wanderer
wahoonc's Avatar
I use a 12 volt Viair 88P. 12 volt but kicks butt. We use them on the farm.
Aaron
wahoonc is offline   Reply With Quote
Old 07-28-2016, 06:06 PM   #5
SeaDog's Avatar
I need to get off my tail and find a air compressor to carry that is light weight and at least 100 psi the Viair's are compact but pricey. I like the looks of the CH with the tank.
Retired Navy
2016 Flagstaff 26 FKWS
Old 07-28-2016, 08:41 PM   #6
Always Learning
If you need 100psi, make sure the compressor is rated for quite a bit higher. I had a Porter Cable 3 gallon pancake compressor that the specs said 135psi. It maxed out at 108 and wouldn't budge.
Good compressor if it works for you, though.
Old 08-01-2016, 03:19 PM   #7
I carry an inflator , 250 PSI, 12V----not sure of the name. It is for emergency use only.
Marvin
GA_Boy is offline   Reply With Quote
Old 08-01-2016, 03:33 PM   #8
I carry a DeWalt pancake in the truck. It comes in handy every once in awhile.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
bshort is offline   Reply With Quote
Old 08-01-2016, 03:47 PM   #9
BamaBob's Avatar
We use a Porter-Cable. 150PSI and reasonably priced. I actually LIKE the fact that it is 110V
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And yes it will air up a motorhome tire - confirmed THAT after I failed to properly tighten our TST 507 Flow Thru sensor on our tag axel tire
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 08-01-2016, 04:09 PM   #10
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
125psi...12vdc $70 Amazon
2019 Sandpiper 379FLOK, F350 Lariat 6.7 DRW, KN4YBP APRS, NRA Benefactors.
dwhit is offline   Reply With Quote
Old 08-01-2016, 07:18 PM   #11
Tbonz's Avatar
compresser
I chose the CH because of its size and will do 110 psi.
Old 08-01-2016, 07:48 PM   #12
I have this mounted under my truck. I can air up any tires within about 25 or 30 feet of my rear bumper up to 200 PSI. It's been so handy!
VIAIR Corporation - Ultra Duty Onboard Air System (P/N 20001)
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-09-2016, 06:38 PM   #13
[QUOTE=BamaBob;1277587]We use a Porter-Cable. 150PSI and reasonably priced. I actually LIKE the fact that it is 110V
+1 what BamaBob said. got same model and it works fine. Didnt like the cheap hose that came with it and replaced that. It fits in my DVD player cabinet in outside entertainment area, and had an electrical outlet handy because of the dvd player, so its ready to go on geny or electrical.
scotttkd is offline   Reply With Quote
