Old 07-24-2016, 08:25 PM   #1
Air compresser
What type of air compressor do you carry. I believe this one will fit nicely in a compartment..110PSI. I prefer a compressor over an inflator.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 07-24-2016, 08:28 PM   #2
cabinet door struts
Also installed struts on the bedroom overhead cabinets..
Old 07-25-2016, 10:06 AM   #3
grumpy0374's Avatar
Sears Craftsman Airboss. Small, compact, 110 volt, powerful.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 07-28-2016, 06:01 PM   #4
World Wide Wanderer
wahoonc's Avatar
I use a 12 volt Viair 88P. 12 volt but kicks butt. We use them on the farm.
Aaron
wahoonc is offline   Reply With Quote
Old 07-28-2016, 06:06 PM   #5
SeaDog's Avatar
I need to get off my tail and find a air compressor to carry that is light weight and at least 100 psi the Viair's are compact but pricey. I like the looks of the CH with the tank.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 07-28-2016, 08:41 PM   #6
Fulltime family RVer
If you need 100psi, make sure the compressor is rated for quite a bit higher. I had a Porter Cable 3 gallon pancake compressor that the specs said 135psi. It maxed out at 108 and wouldn't budge.
Good compressor if it works for you, though.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 08-01-2016, 03:19 PM   #7
I carry an inflator , 250 PSI, 12V----not sure of the name. It is for emergency use only.
Marvin
GA_Boy is offline   Reply With Quote
Old 08-01-2016, 03:33 PM   #8
I carry a DeWalt pancake in the truck. It comes in handy every once in awhile.
2017 Rockwood MiniLite 2506S
2016 Chevrolet HC 2500 6.6L
bshort is offline   Reply With Quote
Old 08-01-2016, 03:47 PM   #9
BamaBob's Avatar
We use a Porter-Cable. 150PSI and reasonably priced. I actually LIKE the fact that it is 110V
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And yes it will air up a motorhome tire - confirmed THAT after I failed to properly tighten our TST 507 Flow Thru sensor on our tag axel tire
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 08-01-2016, 04:09 PM   #10
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
125psi...12vdc $70 Amazon
2014 XLR 415AMP, 2011 F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.2013=180, 2014=184, 2015=216, 2016=220 (7300 miles)
dwhit is offline   Reply With Quote
