Old 08-12-2016, 12:38 PM   #1
Air conditioner
The A.C. in the Concord is not playing the way I think it should. It is a Dometic Penguin 2. With heat pump..it will go along nicely for a while then just shut off..I have the fan set to lo ,not automatic. Fortunately we installed @nother unit in back..it will eventually come back on but I don't like the way it is operating.just wondering if this is the way these highly efficient units operate. The temp outside was around 75 and I had the unit set on 70. Any ideas?
Tbonz is offline   Reply With Quote
Old 08-12-2016, 12:56 PM   #2
Pickin' & Campin'
When it shut off did it satisfy the thermostat?
Mine will shut off set at 70 on a 75 day. That isn't a huge cooling swing.
If you have two A/C's running, I would think it would satisfy very easily.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 08-12-2016, 01:57 PM   #3
Yes I think so but I expected the fan to keep running.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Old 08-12-2016, 05:14 PM   #4
World Wide Wanderer
wahoonc's Avatar
The fan should keep running, at least on mine it does. The only time the fan shuts off is if it is on Auto. High or Low setting and the fan runs continuously. We mainly use that setting at night for the white noise and to keep air moving. I am still a one AC guy.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-12-2016, 06:07 PM   #5
Pickin' & Campin'
Yes, you didn't mention what brand A/C you have but almost all units will shut fan off when auto is selected and thermostat is satisfied.
In high or low the compressor shuts off when the thermostat is satisfied but the fan will continue to run.
The EXCEPTION being on Dometic units with a digital thermostat, the fan will run when set to Auto when in furnace mode. This helps circulate the warm air that rises. It won't run if lo or high is selected.
Old 08-12-2016, 06:31 PM   #6
It is a Dometic. Appears to work well when it is hot out but at night when it cools down it has problems. Has ran flawlessly all day..I to set the fan on hi or lo at night for the noise..but the unit shuts down..And I don't have a book on it. Everything but A.C.. I am
not fond of this digital thermostat nor the heat pump..says it won't work if outside is under 40..Yippee
Old 08-12-2016, 06:40 PM   #7
B and B's Avatar
You can find all manuals online for the AC system. Also at the Forest River site.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-13-2016, 10:12 AM   #8
Land of the Midnightsun
jjSpeedwagon's Avatar
I bet your freezing up. Mine has done that couple times. And above comments are right about using auto it will turn off ......With my 2nd ac in bedroom I run both on low fan speed
John & Janice
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 08-13-2016, 11:33 AM   #9
Not a blip since then.working very well.
air conditioner
