How much air do i need to put in rear tires of a Coachman Concord 22le which is 24 ft usually don't run with much water in tanks and 3 normal size people around 150 lbs each. Thanks in advance for the help.
Larry
I doubt anyone is likely to recommend pressures. Check tires for their load and pressure rating then I suggest you weigh your unit empty and packed for your typical trip at a CAT scale. Check online for your tire brand's weight/inflation chart and inflate appropriately.
Paul
__________________ Big Dog House On Wheels
2013 Coachmen Freelander 28QB on 2012 4500 Chevrolet Chassis
Paul
