Old 12-22-2014, 10:38 AM   #1
Air in rear tires Coachmen Concord 22le
How much air do i need to put in rear tires of a Coachman Concord 22le which is 24 ft usually don't run with much water in tanks and 3 normal size people around 150 lbs each. Thanks in advance for the help.
larryhobby is offline   Reply With Quote
Old 12-22-2014, 10:41 AM   #2
Looking at getting crossfire system so i need to purchase correct air pressure crossfire system
Old 12-26-2014, 07:20 PM   #3
This ia 225LE
Old 12-27-2014, 04:25 PM   #4
B D HOWie's Avatar
Larry
I doubt anyone is likely to recommend pressures. Check tires for their load and pressure rating then I suggest you weigh your unit empty and packed for your typical trip at a CAT scale. Check online for your tire brand's weight/inflation chart and inflate appropriately.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 12-28-2014, 02:58 PM   #5
Thank you one and all for responding, looks like 65 lbs in front and 80 lbs in rear duals as recommended by info on drivers side door. Thanks again
tire, tires, coachmen
