Old 08-22-2015, 10:26 AM   #1
Antenna booster
i have a antenna booster and for some reason it is not working, there is a light for it that is not on and the surround sound light is not on either, I have checked the power (fuses,breakers and GFI )everything is good, what am I forgetting? Thanks for help in advance
PS its for s 2008 Sportcoach Legend
425 HP if that matters Bill
Ruffin it is offline   Reply With Quote
Old 08-22-2015, 10:57 AM   #2
There should be a button right next to the light that you say isn't on.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 08-22-2015, 10:57 AM   #3
Is your 12 volt switch "on"? On my TT this will cut power to those two.
Brewhedd is offline   Reply With Quote
Old 08-22-2015, 02:56 PM   #4
Thanks guys, somehow I found it, it now works but the tv reception is no better Thankd again Bill Hutchinson
Old 08-22-2015, 04:26 PM   #5
Is the TV set to AIR and not CABLE? Did you rescan the TV?
Glen & Lee
Dawsonville, GA
2017 Ford F350 PSD
Old 08-23-2015, 03:14 PM   #6
tv
Glenn I did do the air / cable setup and also the rescan with no luck, thanks for the ideas I was in a heavily wooded area so that was probably part of my problem
Bill Hutchinson
Old 08-23-2015, 03:27 PM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
You can move the ant also. You also may be to far out to pick up channels. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 09-08-2015, 09:12 PM   #8
Blackhat6mike's Avatar
I get "zip" without the antenna booster on and several stations once activated, depending where I am.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
antenna
