Old 04-29-2013, 11:48 AM   #1
Roll's Avatar
Bathroom sink, plumbing issue?
On de-winterizing yesterday I discovered I have very little water flow to the bathroom sink, hot or cold.
Kitchen sink is fine, hot and cold, so is the shower and the toilet (cold only). In fact the pressure to all is robust with good volume.
I don't get it. Worked fine last winter and I (thought) I winterized completely. No water coming out or leaking anywhere I can see inside or outside of the coach.
Very confusing. I'm about to crawl under the coach and see if I can find if the lines to the sink to check for an obstruction or to find out if they are crushed.
The water heater is no longer bypassed and I get hot water (though I have not actually turned the water heater "on" as yet) through all the warm water faucet's, except the bathroom sink, (it is both the sink hot and cold that are not flowing).
My shower, toilet and bathroom sink are all in one room and I assumed running off the same water line feed but I don't know that for sure.
Could it be an air bubble somewhere and if so how would I get it out?
Thoughts anyone?
Thanks in advance.
Roll
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 04-29-2013, 11:54 AM   #2
jtstromsburg's Avatar
More than likely, just need to clean the faucet aerator /screen filter is all.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-29-2013, 11:57 AM   #3
TURBS's Avatar
I concur
Old 04-29-2013, 12:03 PM   #4
Roll's Avatar
Well, as simple as that sounds I had not considered it. Thank you, will do and if that solves the problem I'll owe you both a "beer" which brings my "beers owed" up to a double digits.
Thanks,
Roll
Old 04-29-2013, 12:05 PM   #5
Ditto, and throw the restrictor in the round file.
Old 04-29-2013, 05:55 PM   #6
Roll's Avatar
Yup, that's what it was. Cleaned out the aerator/ screen and the faucet works fine.
Thanks all.
Roll
Old 04-29-2013, 06:22 PM   #7
1nshort's Avatar
faucet screens
Thanks all.
Roll
Yep, them screens are a pain. I buy a bunch from my local (real) hardware store and replace them each time I dewinterize. They crud up probably by lime or mineral buildup and probably some corrosion. You could also soak them in lime-away or such.
2013 Encounter 37TZ, Chalet Pkg, Escape Hybrid Toad,
Denis & Gail & Dixie the Blue Merle Sheltie
1nshort is offline   Reply With Quote
