Old 04-26-2015, 07:19 PM   #1
Batteries for 2013 Pathfinder MH
We have a 404RB Coachmen Sportscoach Pathfinder Elite. Anyone know if the 4 house batteries are 12 volt or 6 volt?
Thanks in advance.
DorisStanKing is offline   Reply With Quote
Old 05-02-2015, 04:32 PM   #2
fedexflyer's Avatar
I have a 2011 Pathfinder 405FK and it has (4) 6vdc batteries for the coach. You can look at how they are hooked up if your not sure. A pair of 6vdc batteries will be hooked up in series with cables + to -, and then each pair in turn hooked up in parallel + to + and -to-. If they are all 12vdc (not likely as the 6vdc end up with more capacity) they will all be hooked up in parallel only.
fedexflyer is offline   Reply With Quote
Old 05-02-2015, 09:29 PM   #3
Thx for the reply.
Old 05-14-2015, 10:55 PM   #4
Hugh R's Avatar
If three cells per battery then 6Volt, if six cells then 12 Volt.
Hugh R is offline   Reply With Quote
2013, battery
