Old 08-17-2016, 01:27 AM   #1
Best way to level without jacks
We just purchased a 21QB Coachman Freelander. Before taking it on the road I want to purchase something on the less expensive side to keep the RV stable. Any suggestions would be greatly appreciated.
RickRed52 is offline   Reply With Quote
Old 08-17-2016, 06:08 AM   #2
waiter21's Avatar
I carry several different lengths of 2x8, They can be used for different things, but I've never had to use them to level the MH. Thats the main reason I carry them.
I have bubble levels mounted on the wall and below the dash so I can see them from the drivers seat, I can usually drive back and forth and get re-positioned so the MH is reasonably level without blocks.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-17-2016, 08:03 AM   #3
That's helpful to know if the issue was leveling the RV. I was asking about stability. I don't have jacks. I'm assuming if I went back to the dealer, I'd be charged something like $250 per jack maybe more. I wanted to know if there was a less expensive option.
Old 08-17-2016, 11:29 AM   #4
I use2x8 short boards but as stated above, I hardly have to use them. You need to install levels easily observed while in drivers seat.
Marvin
GA_Boy is offline   Reply With Quote
Old 08-17-2016, 11:54 AM   #5
Do you want to level or stabilize? The title says level but your description says stabilize (these are 2 separate things.....)
If you just want to stabilize then google "rv pyramid jacks", they are about $30 for a set of 4, I used them on an older SOB trailer and I use them for my newer EVO and they work well.
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-17-2016, 12:13 PM   #6
RETIRED
n-e-d's Avatar
Location: Home of the 4 time Super Bowl Champions Patriots. One more win and No. 5 is in sight.WAHOO
X2 SuicideSaints for strictly stabilizing stack jacks will work fine. Look the same as the ones my father had us using 50 years ago
Mary and Me
2015 2650s
2015 Jeep Cherokee
n-e-d is online now   Reply With Quote
Old 08-17-2016, 01:55 PM   #7
You said level but I guessing you meant stabilize, I bought four scissor jacks on e-bay for my cargo trailer a couple months ago for $100. You might check there.
Las Cruces is offline   Reply With Quote
Old 08-17-2016, 02:06 PM   #8
these are lite, stack into small package, and not expensive,.... I've used them and they do a good job,......
https://www.amazon.com/Camco-44560-O...camco+rv+jacks
fella10 is online now   Reply With Quote
Old 08-17-2016, 02:11 PM   #9
These are what I was talking about, best bang for the buck in my opinion. I use 4 on my 28 foot evo and they keep it rock solid. I put 2 near the axles towards the rear and 2 up front near the bedroom of my trailer the bounce/shimy is gone.
Old 08-17-2016, 03:04 PM   #10
Professional Texan
TexasBob's Avatar
If that works for you, just do it.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
jacks
