Old 11-12-2019, 08:18 PM   #1
Black Tank Design Flaw
2020 Mirada 37RB.
We are staying in the motor home for the winter. We are having problems with the black tanks. They are backing up into the toilets when the tanks are less than half full. We have had RV’s for decades so we know to put plenty of water in the tanks to help prevent the Pyramid of doom, but it is happening anyway.
From what I can tell there are 2 things that come together to create this problem; First is the tanks are shallow so it takes a lot of gallons of water to cover the bottom, let alone be enough to distribute the solids, consequently the solids build up under the toilet inlet quite easily. The second problem is that both of the toilets are on the right side of the motor home and the outlets are on the left side of the motor home so when the tank is dumped the liquids do not pass by the solids that are built up under the toilets. The black tank flush takes quite a while to clear the deposits, dumping a bucket of water down the toilet seems to work to get things to clear.
Has Anyone else had this issue and found a good solution?
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
DougW is offline   Reply With Quote
Old 11-13-2019, 01:10 PM   #2
Sounds like you're not using enough water after the 'fact'.
Have you thought about trying the Geo Method of tank maintenance? It might help with the issue as it helps keep 'stuff' from sticking to the tank surfaces.
Gotta go campin!
Old 11-13-2019, 01:22 PM   #3
I am sure we are using plenty of water. It also does not seem to be a problem of sticking to the tank. These tanks run the full width of the motor home so they are very very shallow, maybe 4 or 5 inches tall so it takes 15 or 20 gallons of water to put a couple of inches deep in the tanks. It appears there is just not enough water depth for the solids to move around in the tanks unless the motor home is in motion, and we are set for the winter so movement is not going to help like it does on shorter trips.
Old 11-13-2019, 06:17 PM   #4
We had the same problem with out coachmen pursuit 31SB. the problem was that the tank was shallow to go across the frame and then dumped into a deeper tank on the left side of the rv. So if you put a several gallons of water into the tank it would just settle on the left side. the result was the toilet paper and the solid waste would build up while the liquids would run into the deeper section of the tank.. The final solution for us was to have a macerating toilet installed. Coachhmen agreed to pay for the new toilet because of defective design. We have had zero problems to this date.
DaveandChris is offline   Reply With Quote
Old 11-14-2019, 08:42 PM   #5
toilet problems
I am still waiting for Coachmen/ Forest River to step up and fix my toilet in the 30FW Pursuit? Wrote two different people at FR that were recommended on this site. Never so much as got a reply? Not good for word-of-mouth recommendations.
Bytesponge
Bytesponge is offline   Reply With Quote
Old 11-15-2019, 12:59 AM   #6
Lightbulb
If you and your family each eat a bout 2 cans of beans at every meal you won't ever get the "Pile of Doom" syndrome and problem! Problem solved!
grandpawrichard is offline   Reply With Quote
Old 11-15-2019, 01:37 AM   #7
CincyGus's Avatar
Always more ways to skin a cat than one as Grandpaw Richard proves I guess ;-)
Definitely sounds like a design flaw on the depth of the tank. If your unsuccessful in getting manufacture assistance, my thought would be to tap into the cold water line that feeds the toilet and put a spray hose hanging on the wall behind it. I've actually seen these on some models to give you a little more force to rinse the bowl with and it sounds like it might do the same trick the bucket of water down the bowl is doing at a much lower cost that replacing the toilet or tank would. Just a fairly inexpensive solution I would try first if I were in your situation. Good Luck.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 11-15-2019, 08:34 AM   #8
That sounds like a case of the solution being worse than the original problem.
There is already one of those sprayers on the wall, it works to rinse the bowl when needed but does not have enough force or flow to help with the buildup in the tank.
Old 11-15-2019, 08:51 AM   #9
Semperfi24's Avatar
This seems like a stupid problem for an owner to need to deal with, particularly with the cost associated with these vehicles. If you have had success with the bucket of water method, perhaps your answer is to put a few gallons in the bucket. When you finish, dump the bucket as a final step in the process. You will be forced to dump more frequently, another added annoyance, but that might be your answer, unfortunately.
I have also always wondered to myself, why the f*** is the tank opening (pipe location where the tank contents flows when dumping) are on one end of the tank, rather than in the middle of the tank. This would require the tank to slope from all walls toward the center and down into a pipe that then exits the tank... Maybe its a ground clearance issue? So the edges of the tank might be 10" deep (I'm just making up numbers here), and the center might be 14" deep. Everything, liquid, solid, paper, etc would have an easier path to vacate the tank.
My above thought is very simplistic, and there would certainly need to be more thought put into it, as in, the ideal scenario is to have the toilet directly above that exit pipe, and since toilets are rarely in the center of the RV, you would need custom tanks with that exit pipe sometimes in the center of the tank, sometimes toward one end of the tank, etc. Just my thought. The RV industry relies on gravity to dump the tanks, but they only slope the pipes, not the tank bottom... And a shallow tank is going to be even worse... Maybe I need to be in the custom gray/black tank business, lol
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 11-15-2019, 09:14 AM   #10
These folks beat you to the punch on your custom gray/black tank business as they can make about any configuration of tank required. The bottoms of all the "holding" tanks they show are sloped.
https://www.alphallc.us/tanks/
Feel Swift is offline   Reply With Quote
Old 11-15-2019, 09:41 AM   #11
Semperfi24's Avatar
A day late and a dollar short... Bummer. Guess I need a new master plan.
black, black tank, tank
