11-28-2013, 11:17 AM
Black tank flush
Which black tank flush does coachman use on Concord
11-28-2013, 11:34 AM
Is there more than one type?
11-28-2013, 01:21 PM
Always Learning
I imagine there are multiple brands.
11-28-2013, 06:08 PM
Not sure it's a brand so much as a design. Our 2005 Concord had several spray heads inside the tank, and from the way our new Georgetown operates, I think it's the same basic design.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
12-01-2013, 01:11 PM
Where is the cleanout mounted on the black tank? Is on the side or on the back and how far from the top of the black tank. Thanks for the info
12-01-2013, 01:17 PM
OK, I'm stumped on this one. Not sure what you are referring to as the "cleanout"?
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
12-01-2013, 02:10 PM
Clean out is a nozzle in the black tank that sprays the inside to wash any gunk to the bottom of the tank and then flush it out.
You may have a separate connection for the water hose near the fresh/city hook up.
12-02-2013, 11:16 AM
Yes, I understand what the black tank flush is, I was just stumped by the use of the term "clean out" as in plumbing terms, that would represent an opening to access a waste line to....clean it out.
Maybe larryhobby would like to expand on his question - why are you needing to know exactly where the "clean out" (spray nozzle inside the tank) is located?
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
12-03-2013, 07:31 AM
I am adding black tank flush to MH, will some look under their Concord and either take a picture or let me know where on black tank is flush located. Again thanks in advance.
12-03-2013, 11:59 AM
OK, understand your angle now. I don't have a Concord, but my suggestion would be to add it wherever you can easily access it. I'm certain that most are mounted at or near the top of the tank so as to direct the spray around and down toward any solids that need to be washed out.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
