Old 08-11-2016, 10:32 AM   #21
BlackJeep22's Avatar
Looking to purchase a few more accessories for the coach. Looks like etrailer has a "low price guarantee". I'm finding that the 2 leading manufacturers are CAMCO and VALTERRA. Anyone have an opinion whether one is typically better than the other? Is it a Ford or Chevy thing?
I'm looking to buy:
  • Sidewinder type sewer hose support
  • Drinking water filter
  • Flush King type black water tank flush
Thanks,
Steve
BlackJeep22 is offline   Reply With Quote
Old 08-11-2016, 10:43 AM   #22
Land of the Midnightsun
jjSpeedwagon's Avatar
I've got some camco stuff. Water filter. I think my water fittings brass Y, elbow , water regulator ..get on Amazon and put in camco rv. My water hoses are quality with stainless fittings ...poop hose is rino brand ,don't forget clear 45 degree fitting so u can see when black tank is clean
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 08-11-2016, 11:05 AM   #23
Got that one already. Thanks.
I was thinking about a "Y" fitting for water. Having NEVER hooked up to a camping site, I've never seen whether there are multiple water hookups or typically just one. Seems like a good idea to screw on a "Y" and hook both hoses to it.
Old 08-11-2016, 04:18 PM   #24
World Wide Wanderer
wahoonc's Avatar
The smaller Camco stuff is decent, buy a fair bit of it myself. I avoid their more pricey electrical stuff, seem to have problems with it.
I carry a wide range of adapters and such for water and electrical.
In my freshwater plumbing box I carry: a wye, a water thief and a water diverter, 90 elbow, a short 6" extension hose, 2 white water hoses, 10' and 20' I think, regular 15' garden hose, a couple of the cheap regulators and one good adjustable regulator some screw in plugs for the end of the water lines where they go in the faucets. I have had a faucet go bad, I was able to plug the end of the line and keep on camping, and a couple of the blue water filters. I usually write the date I start using the filter on it with a sharpie, figure they are good for 6 months/season or until they get plugged up. Last one got silted up pretty quickly due to chunky well water at one campground we stayed at. I need to add a couple of shark-bite fittings in whatever size the pex is in the unit along with a couple of short pieces of pex.
Electrical: Portable EMS, 50/30 amp adapter, 30/15 amp adapter, spare male 30 amp end, 30 amp extension cord, 25' 12 ga drop cord and a 3way power block. Along with some fuses for the 12 volt size.
I probably have more than that, but that is what crosses my mind at the moment. I may not need all of it, but some things have come in handy helping out fellow campers.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-11-2016, 10:12 PM   #25
Thanks, Steve & Deb
2016 Coachman Concord 300DS
-Safe-T-Plus | Garmin RV 660 MLT
2008 Jeep Sahara
-Blue Ox base plate | Ready Brute Elite
Old 08-12-2016, 04:18 PM   #26
So, I finally crawled underneath today to take a look at the plumbing, etc. The Black tank and the 2 Gray tanks are pretty obvious, and it looks like the Gas tank is the big metal one in the center of the chassis. I didn't see anything obvious regarding the water tank. Where exactly is the water tank located?
Looking at the plumbing, and trying to remember what the tech briefly touched on during the walk through, I don't see any way to dump the gray tanks into the black tank to help flush it out. It looks like all they will do is flush out the stinky slinky. I could have sworn she said the gray tanks dump last to help clean out the black tank.
I found the 3rd knife valve for the gray tank on the passenger side. It's currently pulled OUT as expected. What do you suppose this valve is for, since there is another one in the dump station location? Seems like belt and suspenders.
Looking at the potable water connections behind the door, (photo attached) could someone please explain the sequence these were meant to be used?:
  • What is the Pump Switch for?
  • What does the Light Switch do?
  • The Blue Valve. I know there is a diagram there, but (for clarity) could someone explain this a little better please?
  • The White knob is for flushing the Black tank, using the hose for just this purpose? I'm assuming this is done with the black tank knife valve closed to build up some weight, being careful not to overfill? I'm planning to get one of these, to assist with the flushing. Is a water pressure reducer required for this?
  • The Black Inlet connection is to fill the potable water tank, with the Blue Valve in the horizontal position? Is a water pressure reducer required for this?
Thanks again, in advance.
Thanks, Steve & Deb
2008 Jeep Sahara
Old 08-12-2016, 05:12 PM   #27
World Wide Wanderer
wahoonc's Avatar
The fresh water tank is above the floor in the bedroom underneath the wardrobe towards the front of the coach, remove the black panel (4 or so screws) and you will see it.
Gray water won't rinse the black tank, just the outlet and the stinky slinky which is why you dump black first.
The valve on the right side is for winter use. If you are in freezing weather you don't want the gray water from the right side tank sitting in the pipe, it could freeze and break the pipe so you close the valve at the tank and turn the tank heaters on. The gray dump valve for that tank on the left side is for convenience. Now you know why I want to switch to electric. Eliminate one valve and control everything from the left side.
The light switch... wait for it... lights up That provides the light for that panel. Amazing ain't it.
The pump is so you can pull antifreeze into the system when you are winterizing (at least that is how I think it works, I missed that part of the class too. )
The white fitting is for the black tank flush, it is STRONGLY recommended that you leave the tank valve open. I am functionally illiterate and close my black tank valve to allow water to build up in the tank. However you need to be extremely careful not to overfill the black tank it will create one helluva mess. I haven't done it, but have observed the aftermath of someone that did. You may or may not need a pressure reducer on it depending on just how much pressure you are dealing with.
I do run the pressure regulator anytime I am hooked up to city water or filling the water tank.
The blue valve has two positions, the one you have it in right now is for filling the tank or pulling antifreeze into the system. If it is pointed down you are using city water and bypassing the tank, no pump needed.
Aaron
Aaron & Rhonda
Old 08-12-2016, 07:55 PM   #28
Aaron
Aaron,
Thanks so much for all your help. So, in your typical setup for the fresh water, what is the sequence of all of your various fittings? Do you first screw the pressure regulator onto your campground faucet or elbow... then your "Y". Do you have "quick disconnects" at each outlet of the "Y"?
Not sure how that Water Thief/Bandit works, must be for old worn out threads?
Any opinions regarding ordering from etrailer vs. RV & Auto Parts? etrailer has a "best price guarantee" but RV & Auto Parts beats them at everything on my list.
Thanks, Steve & Deb
2008 Jeep Sahara
Old 08-12-2016, 08:32 PM   #29
World Wide Wanderer
wahoonc's Avatar
I don't normally use the quick disconnects I carry a pair of pump pliers in my tool bag to tighten things up with.
The order of things varies a bit depending on how long I am going to be staying somewhere and where the water spigot is located, how close to the ground, etc.
Typical setup is the water diverter on the campground sillcock, then a hose, then the filter, then the flex hose, then the pressure reducer then the 90 elbow. I want the filter to get water at a higher pressure to push through the filter medium.
I have bought from etrailer and have no complaints, I have not purchased from the other one. Most my stuff comes off Amazon as add ons to my larger orders. I have a prime account so stuff ships free. I also buy from RVupgrades.com for some stuff, as well as a quasi-local dealer a couple of hours up the road, they are an older dealer and have a huge stock of small bits and pieces that can be hard to find in small quantities.
The water thief/bandit is for damaged threads or no threads, if no threads you may have to run a hose clamp around it to make it work. It does not like high pressure.
Aaron
Aaron & Rhonda
Old 08-13-2016, 06:12 AM   #30
World Wide Wanderer
wahoonc's Avatar
I also buy stuff at Wallyworld if I happen to be spending the night or passing through. Not my favorite place to shop. For some reason they have had the best price on the blue filters... usually.
Aaron
Aaron & Rhonda
black
« Refrigerator doors | - »
