Old 08-15-2016, 10:54 AM   #41
World Wide Wanderer
wahoonc's Avatar
Originally Posted by BlackJeep22 View Post
I'll give it a shot today, hopefully. I watched a couple videos where a guy spliced into his on-board water pump lines, hooked up an electrical on/off toggle switch, etc. This would be GREAT if it's already set up.
So how do you get chlorinated water in your FW tank, if you don't use this external pump switch and a bucket?
City water is chlorinated and will stay good for several weeks. One of the reasons I don't drink it or use it to make coffee.
I have access at home to both city water (treated) and well water (untreated). We use the well water for drinking and cooking. We fill up a couple of gallon containers for drinking purposes. If it runs out we buy gallons of drinking water. I don't have a problem with drinking water out of a properly sanitized RV system, just don't like the plastic flavor it picks up.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-15-2016, 10:58 AM   #42
BlackJeep22's Avatar
Aaron
Gotcha! Thanks Aaron. Any idea what the full capacity is of our FW tank?
BlackJeep22 is online now   Reply With Quote
Old 08-15-2016, 11:07 AM   #43
World Wide Wanderer
wahoonc's Avatar
47 or 49 gallons... I figure whole system is just over 55 gallons with the water heater, lines and tank filled.
Aaron
Aaron & Rhonda
Old 08-15-2016, 12:40 PM   #44
Aaron
Thanks Aaron... Have a great day.
Old 08-17-2016, 01:21 PM   #45
Stinky Slinky Storage
My first modification, aside from removing that sewer "swing out contraption".
2 - 4 foot sections of 5" square PVC fence posts. Easily stores both 10' sections of sewer lines.
ID:	117573   Click image for larger version
ID:	117574   Click image for larger version
ID:	117575   Click image for larger version
Thanks, Steve & Deb
2016 Coachman Concord 300DS
-Safe-T-Plus | Garmin RV 660 MLT
2008 Jeep Sahara
-Blue Ox base plate | Ready Brute Elite
Old 08-17-2016, 08:51 PM   #46
World Wide Wanderer
wahoonc's Avatar
Nice job! I think I am going to go the 6" thin wall PVC route, mainly because I have a bunch of it all ready laying around. We are headed to the lake (state park) this weekend. Only planned mod is converting full beer bottles to empty beer bottles.
Waiting on some cooler weather to get here so we can REALLY start camping!
Aaron
Aaron & Rhonda
Old 08-17-2016, 10:17 PM   #47
Aaron
Thanks Aaron. I looked around Home Depot for round thin walled, but didn't see any. One of my favorite things is emptying out those damn full beer bottles. Have fun at the lake.
Thanks, Steve & Deb
2008 Jeep Sahara
Old 09-01-2016, 06:58 PM   #48
Wink
The pump is so you can pull antifreeze into the system when you are winterizing (at least that is how I think it works, I missed that part of the class too. )
Aaron
Well, I finally got around to trying to put some bleach water in my fresh water tank for sanitizing. Turns out that Pump Switch (inside the water station door) is exactly the same switch as the one inside the coach on the control panel. It does NOT pump water into the fresh water tank. I think this switch is just so you can control running water through the faucets (inside) without actually going inside and pressing the pump switch. I was hopeful that this was a well thought out "built-in" pump for pumping anti-freeze or bleach water into the fresh water tank.
As a result, I decided to just order this for now, to pull my 4 gallons of bleach water into the fresh water tank.
I should have read the reviews a little closer, this may just be junk. If it is, I think I'll go with this little guy.
Thanks, Steve & Deb
2008 Jeep Sahara
Old 09-01-2016, 07:33 PM   #49
Land of the Midnightsun
jjSpeedwagon's Avatar
You ninnies. Lmao. The pump switch outside is to turn the pump on for outdoor shower. :roflb lack:
John & Janice
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 09-01-2016, 08:00 PM   #50
Hey have ya'll been sneaking peaks at this?
John & Janice
black
« Our pursuit 27KB | - »
