09-18-2016, 06:59 PM
#121
Originally Posted by richardelarson
One of two possibilities. 1) Each Jack has a limit switch that the foot plate pushes up on when they retract. You will see it on the side Jack.
Dick
Hummm... My Right rear doesn't have one of these switches... and the hex bolts are too big for me. Biggest I have is a 22mm. I'll have them check them when I have the steering stabilizer installed tomorrow.
Thanks, Steve & Deb
2016 Coachman Concord 300DS-SOLD
2011 36QSH TIFFIN PHAETON
Garmin RV 660 MLT
2008 Jeep Sahara
-Blue Ox base plate | Ready Brute Elite
09-18-2016, 07:26 PM
#122
I know it seems like it but it will settle out. Finding the solutions is sometimes a challenge but it's also kind of fun ...... after its fixed.
YA... I checked the gas stove today and the left rear doesn't fire. I could smell gas, but no flame on.
They told me, I'd have a list of things to be fixed after the first time out, but this seems crazy... We haven't even BEEN out yet.
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-18-2016, 07:34 PM
#123
World Wide Wanderer
Use the emergency retract and see if it brings them all the way up. I had one limit switch that was bent and only hit the pad sometimes, took a pair of vice grips and tweaked it a bit.
On the rear burner on the stove, pull the top and make sure the igniter is mounted, mine fell out once, pliers on the bracket to tighten it up and it has worked ever since.
There will always be things that need attention on an RV. Imagine what would happen to your house if it had to survive an earthquake and hurricane every time you used it.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
09-19-2016, 03:18 PM
#124
Aaron
I did try the emergency retract yesterday, to no avail. I took it into an RV repair shop this morning to have my new Safe-T-Plus steering stabilizer installed and asked them to please check out the Bigfoot beeping and flashing. Looks like it may be covered under warranty.
When looking at my sensors yesterday, I noticed that I only have 3. No sensor on my right rear jack. I just called Bigfoot and he says this is most likely the problem, the system still thinks that jack has not fully retracted. I'M TELLING YOU... THIS COACH IS CURSED!
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-19-2016, 06:16 PM
#125
Bigfoot Jack System beeping/blinking UPDATE
I called Bigfoot today while my Concord was in the shop getting a Safe-T-Plus installed. I told them about the beeping and blinking on the Bigfoot controller and that when I went around to check the jacks, I noticed that the right rear jack didn't even have a sensor. He said, "Well, that's most likely your problem". He was surprised that I hadn't noticed it prior to yesterday. I explained that I just got the coach in July and had been waiting for license plates and bugging all you guys with all my newbee questions in the interim.
I also mentioned that after I got it home, I had a Mobile Tech come to my house to replace the defective coach batteries. While he was here, I asked what he thought these 2 hanging wires went to. After poking around, he didn't seem sure, and I didn't know exactly what he did. I had not driven the coach since this service call.
Apparently, those 2 wires were supposed to hook into the invisible/missing jack sensor. When he hooked them together, he created the problem and Bigfoot thought a jack was still down. AMAZING!
Parts are on order. When will it end?
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-19-2016, 06:48 PM
#126
World Wide Wanderer
Went and checked... yup should be a sensor on every leg. I had a couple of issues with mine due to excessive mud build up. Cleaned everything up and it works just fine.
Aaron
Aaron & Rhonda
09-21-2016, 01:46 PM
#127
Any actual axle weights yet?
Anyone weighed their Concords yet?
I talked to a Forest River guy yesterday about recommendations for tire pressure and he said that Michelen has a chart on their web site that is based on axle weight.
I had 2 rear tires remounted and valve stems replaced yesterday and the tech set my tires to 65 in front and 70 in the rear. Sounds WAY low to me.
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-21-2016, 07:58 PM
#128
World Wide Wanderer
We were waiting on you to do it!
I haven't had the chance yet, sad part is the scales in only a couple of miles up the road at the county dump.
I run 70 psi in the fronts and the rears and the airbags. So far so good. I have a sneaking suspicion that we are going to be nose heavy with that big V-10 up there, which is probably why Coachmen put the water tank way in the back behind the axle.
Aaron
Aaron & Rhonda
09-23-2016, 03:05 PM
#129
Refrigerator while on the go?
Heading out tomorrow morning on our maiden voyage. Heading to Sisters, Oregon... about 170 miles away.
We're taking a cooler, but how do most of you run your refrigerators while enroute?
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-23-2016, 03:15 PM
#130
I run mine on propane
Retired Navy
2016 Flagstaff 26 FKWS
09-23-2016, 04:07 PM
#131
Us too. We never take a cooler. Just turn on the fridge and let it automatically select gas. I have to watch mine to make sure it fires up. Sometimes it wants to time out and not stay lite. I shut it off and start again. Every time it stays on on the second try. John t so you know the freezer will get cold first and usually good enough in a couple hours. The Fridge takes longer. At least 4 hours. Then I load it. I've run the fridge for a number of days on propane and it hardly uses any.
09-23-2016, 06:51 PM
#132
DW's 401(k) Plan
My fridge is always on - I keep my 3010DS plugged in while home - and the fridge is on AUTO. When I disconnect the shoreline , I do stand by the fridge vent until I hear the propane light. Then I know I'm good to get on the road. So, to answer your question, propane.
Have fun on your trip!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
09-23-2016, 07:29 PM
#133
You obviously don't drink as much beer as me.
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-23-2016, 07:38 PM
#134
DW's 401(k) Plan
If I remember correctly, last camping trip we had a 30 pack of beer, a 12 pack of Mike's and a case of Smirnoff Triple Black - all in the fridge. For the weekend. Came back with most.
09-24-2016, 08:13 PM
#135
Coaxial cable! Damn, I figured I'd forget something.
Sooooo many things to buy to equip the rig when you're a Newbee. I never even thought about a coax cable for the TV. Luckily, my camping neighbor is a veteran and loaned me his spare. LOVED the way the Concord drove through the mountain roads of Oregon. So far, our FIRST trip is just BITCHEN! 👍🍻
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-24-2016, 08:28 PM
#136
DW's 401(k) Plan
........ So far, our FIRST trip is just BITCHEN! 👍🍻
As it SHOULD be!!!
09-25-2016, 11:11 AM
#137
First time out... Furnace observations
- A bit noisy.
- Nice warmth from the floor vents.
- Cool air from the ceiling vents. What's up with that? Is there a setting somewhere?
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-26-2016, 10:10 AM
#138
Furnace issue resolved
My camping neighbor explained the secret behind getting the furnace to blow ONLY warm air and stop the cold air coming out of the ceiling vents. Pretty simple, once someone explains it.
The big secret was to set the FAN to AUX. Now when the FURNACE comes on, the air conditioner does NOT.
Now, much more quiet and toasty warm.
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
09-28-2016, 05:17 AM
#139
World Wide Wanderer
Got it! Sounds like you camped next to a great guy.
We run the fan on low during the nights in the warmer seasons to keep air moving, wife has to have a ceiling fan on at home. Winter months we will turn it off and use just the furnace. Also like using the fireplace to take the chill off if it isn't quite cold enough for the furnace.
Aaron
Aaron & Rhonda
09-29-2016, 10:46 AM
#140
Furrion Navigation Disk?
As we approach maxing out our cell phone data for the month, I thought I'd finally take a look at the Furrion Nav unit. Looking through all the manuals... I don't see a disk. Did any of you Concord owners get a disk with your coach?
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
