Old 06-07-2013, 08:52 AM   #1
Block heater on 2013 SportsCoach?
I was reading a thread over on irv2.com about block heaters.
I haven't seen anything in any of my documentation about a block heater for the Cummins 6.7 340 hp.
Anyone know if they come with a block heater... and if so, how to activate it? (don't want it on if not necessary by hitting an umarked switch)
Thanks in advance,
Mal
2013 Coachmen SportsCoach 385DS
Maladjusted is offline   Reply With Quote
Old 06-07-2013, 10:08 AM   #2
Roll's Avatar
Can't help you regarding the block heater Mal but you did walk me through changing my base plate from one jeep to another. Thank you for that. I plan to make the change this weekend and looking forward to the project actually.
Sorry for the highjack. Roll
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 06-07-2013, 10:34 AM   #3
daydreaming about camping
jeeplj8's Avatar
Thanks in advance,
Mal
Although I unfamiliar with the install in a class A, every diesel I have seen with a block heater had a 110v cord that had to be plugged in. From my pick-up to semi's the general set-up is the same. In other words, I think there would be a 110v male end cord exiting your engine bay at some place.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 06-07-2013, 11:05 AM   #4
No prob Roll.... if you get hung up during the swap over... I'll help you as best I can.
Mal
Old 07-29-2013, 04:30 PM   #5
mvpmich's Avatar
Thanks in advance,
Mal
In case you haven't confirmed it yet, there is not a block heater in the cummins 340.
mvpmich
2012 Sportscoach Cross Country 385 DS
Freightliner XCR w/ Cummins ISB 6.7L 340 hp
2009 Saturn Vue, Blue Ox Alpha, RVi Brake 2
mvpmich is offline   Reply With Quote
Old 07-29-2013, 05:29 PM   #6
Never confirmed... But suspected. Not overly concerned, my Duramax has the same grid heater on the intake and I've started that motor at 10 below without plugging in!
Mal
Old 07-29-2013, 06:27 PM   #7
mvpmich's Avatar
Mal
I didn't have any problems last winter. Also put on almost 5,000 miles this past month king from Michigan to LA be Grand Canyon and returning by way of Route 66 during the western heat wave 110+ in AZ and CA deserts. No issues. Only one time did engine temp gauge go past midpoint. I was impressed.
Still have some coach issues though.
mvpmich
Old 07-29-2013, 07:19 PM   #8
Excellent!! Not sure if I told you, but I replaced the shower head in ny shower and it made an incredible difference! Even the hot water heater is working better!
I tow a small Chevy Cruze... In 100 degree heat going up a 5% grade for 3 miles, the temp will go to 212 - 214, then the fan will come on and the temp will drop right back to 190. I set the information center up to monitor turbo psi, engine temp and transmission temp.
Good to hear your coach performed well.
Mine is going into Dylan's RV in NJ next week to have the pull out kitchen cabinet fixed (it locks in the out position, not in the in position) and some of the LED lights are out on the awning.
Mal
Old 07-29-2013, 07:29 PM   #9
mvpmich's Avatar
Mine locks in both positions.
You have the upgraded model with LED cupholder and awning lights. Is yours an 'Elite' model or just the upgraded trim package?
mvpmich
Old 07-29-2013, 07:51 PM   #10
Hmmm... Not sure. What else does the "elite" model provide?
I have an outside 32" tv too.
