Old 07-31-2016, 08:44 PM   #1
Cable problem in new Coachmen Freelander 21QB
We are on the road and our cable TV is too fuzzy to watch. We tried it a few days ago and thought maybe it was a bad cable, got new cable, still fuzzy. There's probably something I'm not doing right, any suggestions?
gja1000 is offline   Reply With Quote
Old 08-01-2016, 05:24 AM   #2
Did you turn off the tv antenna amplifier (using the little pushbutton switch) when using cable TV?
2019 Georgetown GT5 31L5
DocP is offline   Reply With Quote
Old 08-01-2016, 05:44 AM   #3
RSchleder's Avatar
If your watching cable TV, turn OFF the antenna amplifier.
Go to your TV menu and be sure the TV is set to cable.
Do a channel scan--do not interrupt the scan.
When scan is complete, you should have a good, clear picture.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 08-01-2016, 10:12 PM   #4
The antenna amplifier was the problem. Because it was on the plate where the cable plugged into, I thought it had to be turned to on for the cable to work, but such was not the case. Thanks for the help
Old 08-02-2016, 04:34 AM   #5
World Wide Wanderer
wahoonc's Avatar
That was an easy one...
I was helping someone last week with fuzzy TV issues. Turned out to be a cheap splitter in the wall, what a pain that was to get to.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-02-2016, 01:14 PM   #6
Any ideas where that button could be located...
roodman is offline   Reply With Quote
Old 08-02-2016, 01:31 PM   #7
Ford Idaho's Avatar
Could be in a cabinet or like mine in a cubby hole under the television.
Should be near the tv someplace.
Old 08-02-2016, 01:56 PM   #8
Left Coast
Look for the wall plate that the coax from tv is connected to....button will be on it..
Old 08-02-2016, 02:11 PM   #9
it could be near any tv in the camper.. there is only one for the whole camper...
rcrupper is offline   Reply With Quote
Old 08-02-2016, 05:22 PM   #10
Hoffwmn's Avatar
X2
Hoffwmn is offline   Reply With Quote
Old 08-02-2016, 05:25 PM   #11
Hoffwmn's Avatar
In the Coachmen Leprechaun 220QB it is on the left hand end of the cabinet above the entry door. I have to stand in the passenger's seat to reach it.
Old 08-03-2016, 05:44 AM   #12
World Wide Wanderer
wahoonc's Avatar
Typically it is mounted on the wall plate with the 12 volt port and the cable outlet. In my Concord it is an overhead cabinet next to the television. I would look in the vicinity of all of your televisions until you find it. Sometimes it is on a separate plate, but that is an exception.
Aaron
Aaron & Rhonda
cable, coachmen
