Old 05-21-2016, 03:48 PM   #11
Originally Posted by Jackstraw6 View Post
I don't think so. Looks like I'd have to take off the whole water control panel to access the tank hose. Water flows through on the tank valve position when the low point drain is open, however.
If you're getting water with the drain open, I'd investigate the vent line. If it's plugged, you may be putting water into the tank until the air in the tank compresses to city water pressure, then nothing else will go in.
2011 Traverse LT, 3.6L, FWD
Old 05-21-2016, 06:12 PM   #12
Thanks. I'm not sure where the vent line is. I opened the compartment under the kitchen sink and found the tank line was kinked but straightening it didn't help. If it's not the vent line then perhaps it's a faulty valve, which someone had mentioned before. The fresh water tank shows 1/3 full from the day I got it till today.
Jackstraw6 is offline   Reply With Quote
Old 05-21-2016, 06:55 PM   #13
Land of the Midnightsun
jjSpeedwagon's Avatar
We have a 2016 300 DS and I bet it's your valve for city water / tank fill. I think I would start there
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 05-21-2016, 07:10 PM   #14
Flybob's Avatar
Do you mean tank drain valve vs low point drain ( blue or red pex). If you are saying water flows when the tank drain valve is open, then the tank vent is plugged or kinked and air can't get out of the tank. Try opening a cold water faucet and then see if water flows when in the tank fill position, If so it is definitely the vent. Be careful if this is the case as connection to a high pressure source, you could expand and damage the tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-21-2016, 07:15 PM   #15
Will do. Thanks.
Old 05-21-2016, 07:17 PM   #16
Sounds good. Thanks.
Old 05-22-2016, 06:21 AM   #17
Low point drain. I have not yet located the tank drain.
fresh water, tank, water, water tank
