Old 05-21-2016, 09:38 AM   #1
Can't fill fresh water tank
I have a 2015 Coachmen Concord 300TS and can't fill the fresh water tank. City water works fine. Thoughts?
Jackstraw6 is offline   Reply With Quote
Old 05-21-2016, 09:48 AM   #2
BendOrLarry's Avatar
Not much to go on here. Why can't you fill it? You can't find the fill opening? It is clogged? What?
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 05-21-2016, 10:03 AM   #3
There is a single inlet for both city and tank with a valve that allows you to switch between the two. When it's in Tank Fill position no water flows in. There is a little pump button but that seems to turn on briefly then off.
Old 05-21-2016, 10:09 AM   #4
Good info so now someone with this set up can maybe shed some light on your issue.
Firestone airbags
Old 05-21-2016, 11:38 AM   #5
I would say the switch valve is faulty. Is there away you can take the tank hose of the valve and try it?
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 05-21-2016, 11:39 AM   #6
Mine has a tank valve that switches from city water to tank fill on a single hose hook up
Old 05-21-2016, 11:40 AM   #7
If water flow out of valve then r hose maybe kink.....has it worked in the past?
Old 05-21-2016, 01:00 PM   #8
I don't think so. Looks like I'd have to take off the whole water control panel to access the tank hose. Water flows through on the tank valve position when the low point drain is open, however.
Old 05-21-2016, 01:56 PM   #9
The low point drains is for draining your water lines for the winter. A least that what mine are for. If you are switch to tank fill, water should be flowing in the tank, unless you have a kick hose behind the panel or somewhere....or it's plugged up with something. In order to get water to r fixtures from the tank u have to turn on the water pump.
Can u hook up an air valve and try blowing the line out. Do not put more than 40 psi in the line. Be sure r vent to the tank is not plugged up, otherwise the pressure may rupture the tank.
Old 05-21-2016, 03:33 PM   #10
It's a new unit so I have never used it before. The dealer said they went through the de-winterizing process and made sure everything worked. Either they didn't or I just don't know what I'm doing. Either is very possible.
fresh water, tank, water, water tank
