Old 06-28-2015, 07:27 PM   #1
chrismbrock2009's Avatar
Changing the oil on my 35bh Coachmen Mirada..lol
First time changing the oil on my 2015 Coachmen 35bh Mirada. Everything was simple and straight forward til it was time to add the oil... lol. The oil fill location is in the most ockward location pretty much making it very tedious to add oil.
Does any of the experienced Ford Chassis gas owners have any tips as far as easy filling?
On the 35BH Mirada you have a small opening in the front of the motorhome to access the engine. So you essentially can not just pour the oil in because of its fill location. The fill location is about a foot higher than the small opening, essentially making it impossible to add oil the old fashion way. Today I had to pour the oil into small cups and then pour it into the fill location. What should have taken 5 minutes took 30.. lol
chrismbrock2009 is offline   Reply With Quote
Old 06-28-2015, 08:07 PM   #2
jk510's Avatar
I used a pump in a 5 qt jug. Then added 2 more qts and pumped some more. Absolutely the most ridiculous setup I've ever seen.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 06-28-2015, 08:11 PM   #3
Lol... link me to the pump you used PLEASE
Old 06-28-2015, 08:13 PM   #4
Would something like this help? Amazon.com: OTC 4848 Flexible Spout Funnel: Automotive
Name:	Flexible spout funnel.jpg
Old 06-28-2015, 08:31 PM   #5
Problem is gravity... you need something to actually pump it ...
Old 06-28-2015, 11:26 PM   #6
Slightly luckier than that with the 2014. The front grill opening is larger. Was able to somewhat crawl in and pour in one quart at a time
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 06-28-2015, 11:29 PM   #7
I think JK510 has the ticket. A pump
Would love to know which one he uses
2015 Coachmen Mirada 35bh
Global Wedding Photographer
Old 06-29-2015, 10:03 AM   #8
Former Full Timer
Duckogram's Avatar
I have used this type for years...
http://www.amazon.com/Marine-Drill-P.../dp/B00EDS36FG
I purchased my latest one at Wally World for about $8.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 06-29-2015, 10:10 AM   #9
jk510's Avatar
This is very similar to what I have.
Robot Check
If you go to amazon and search for oil pump you will find lots of options.
I think I got mine at Autozone some years ago.
Joel K
Southeast AZ
Old 06-29-2015, 02:23 PM   #10
midniter's Avatar
My Mirada 32ds same way. I had to contort myself one quart at a time.
2011 Coachmen Mirada 32DS
midniter is offline   Reply With Quote
coachmen
