Originally Posted by dustman_stx
The Ford V10 produces 457 ft.lb. @ 3250 whereas the Chevy 6.0 produces 380 @ 4200. An extra 77 ft.lb. at 1000 lower RPM is going to be VERY noticeable. There are benefits to the Chevy 6.0, but being the more powerful engine is NOT one of them.
I think the v10 used in the class c is the two valve. It looks like the numbers above are from the three valve available in the class a.
Having owned a ford f350 with a three valve v10 and a class c with a two valve v10, I would say the engine is fine and does what you ask of it.
I would go with the chevy because of the modern steering and more cab room.
