Old 11-16-2016, 01:53 PM   #1
Coachmen Concord gap below TV shelf
I have a Coachman Concord 2013, with front entertainment center. There is a 1/4 to 1/2 inch gap in center of shelf above Chev. Cab and below shelf of TV. This area opens up to front cap over cab area. This area along with TV vibrates and is very noisey on some roads. Is this normal or should this area be secured and is there something missing? Thanks in advance.
larryhobby is offline   Reply With Quote
Old 11-17-2016, 05:38 AM   #2
World Wide Wanderer
wahoonc's Avatar
I would think at the very least there should be a foam seal in there. I have not seen a 2013 Chevy model up close and personal so I don't know if it is normal or not. I would think not. There is not a gap on my 2016 Ford based one.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 11-21-2016, 01:01 PM   #3
Old 11-21-2016, 01:04 PM   #4
This is a picture of what I am talking aboutClick image for larger version
Name:	ImageUploadedByForest River Forums1479751449.540385.jpg
ID:	125554Click image for larger version
Old 04-09-2017, 12:07 PM   #5
I have the same year and chassis and I do not have that gap or those 5 strips of wood that look like they were added for some reason. Are you the original owner?
FedExer92 is offline   Reply With Quote
Old 04-10-2017, 08:58 PM   #6
I am original owner, there was a gap, I put the shims to stablize and it has worked wonders, if you look very carefully there will be a gap, i hesitated to fill in completely as I wanted it to breathe. Please check and see if you find a gap. Thanks for responding.
Old 04-10-2017, 09:19 PM   #7
I don't think there should be a gap. Never seen it before. The weight should rest on the lower section. When you added the shims in effect you transfer the weight to where it should go. That's why it helped
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
coachmen
