Old 07-06-2016, 05:58 PM   #31
World Wide Wanderer
wahoonc's Avatar
Forgot to mention that the pins, adhesive and foil faced insulation is less than $100. My Scottish heritage is showing through.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 07-09-2016, 03:39 PM   #32
World Wide Wanderer
wahoonc's Avatar
Originally Posted by jjSpeedwagon View Post
I have some ac news on one ac on our 300ds. ( hey Aaron wanted to say hi. We've been out and about putting few miles on Moho ) We also from Tex tbonz west Tex but we were over in fredricksburge for the 4th and was park in the wide open sun. Temp was about 104 and I'm sure the sun temp on Moho was 125 plus. Our ac would only drop inside temp to 84-83. So we are going to put another ac unit over the bedroom and I will just run another drop cord for it I hope we can dodge the Tex sun in future but will be glad to have extra ac
Just for the record... it was 95° here the other day and I measured the skin temperature, in direct sunlight it was around 140° What was interesting was the temperature differences between the different colors of the paint. It ranged from low 100's on the light colors to the 140 on the dark stuff. I used a non-contact infrared thermometer that I have. Interior temps were holding near 80 with the thermostat set on 76°. I did some spot checks with the thermometer on the interior walls, a couple checked in at 95° with most in the upper 80's. I am also making some window inserts out of Reflectix.
Aaron
Aaron & Rhonda
Old 07-10-2016, 02:08 PM   #33
Commercial Member
Aaron
That temperature difference is why I am a very strong proponent of White tire covers to protect against UV damage but IMO the more important to lower the tire temperature while parked to decrease the structural damage done to the rubber by excess heat.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 07-12-2016, 10:56 AM   #34
Land of the Midnightsun
jjSpeedwagon's Avatar
Originally Posted by Tbonz View Post
Be sure to keep me posted on the additional AC project ..Thanks.
I got second ac put up. I posted some pics and what I did over on your ac thread I hope it posted ok.
John & Janice
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 07-12-2016, 11:06 AM   #35
Our worst area for heat is cab area I ordered a roll of the double bubble reflective stuff. ( can't think of right name ) but anyhow gonna cut to fit for front windshield and both side door Windows I let Moho heat up over 100 degrees inside. Threw on both ac's and with in 2 hrs inside temp was 73 and falling. No cover on windshield just bare glass. Impressed me. Outside temp ambeant was 102 and sun was full on Moho so with insulation block in windshield and side glass. I think 2nd ac gonna give us what ever temp we need
John & Janice
Old 07-12-2016, 08:00 PM   #36
JJ
JJ what BTU did you add.. ? I ran the wire for mine today and about to order a Dometic 15K . Hope to have it up and running in short order..Did you do the install yourself ? The folk here wanted $1600.00 to do the job I can beat that by half..The hard part was running the wire..
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 07-12-2016, 08:01 PM   #37
Wahoonc, we got the new rig home and if I can figure it out I will post a pic..
Old 07-12-2016, 08:15 PM   #38
I got 13,500 btu. I posted most details on your ac thread. Dometic ac
John & Janice
Old 07-12-2016, 10:00 PM   #39
Also ran LED'S down each side of frame rails today. They will turn any color ya want. Suppose to be water proof. We will see. But gonna run a strip next to Moho under awning then another strip on roller for awning
John & Janice
Old 07-13-2016, 05:41 AM   #40
World Wide Wanderer
wahoonc's Avatar
Sweet! Enjoy!
Aaron
Aaron & Rhonda
coachmen
