Originally Posted by 1nshort
Nelsonc,
The headlights are minor, they were not aligned from the factory. Ours was brought up 4 clicks and that settled the light problem. The wiper/washers you will have to live with...they are weak. I am working on a solution. When I have some news I will publish details and pictures. What is the problem with the shower doors?
The slide could just be an adjustment to the cables...anything else will take some time to fix and hopefully no seal problems. We had a similar problem but a seal was damaged..took a month (dealers were busy).
Good luck for Memorial day, hope you make it.
The left door seems to be mounted cockeyed so that it does not want to stay open. It also does not line up with the right side door.
I think the slide just needs aligned. Looks like the rear engages at a different point when closing and opening.
