Old 03-11-2015, 06:27 PM   #1
Smile Coachmen Prism 2150LE CB Antenna
Hi all,
New to forum .... 1st post
We just bought a new 2015 Prism 2150LE and so far so good after a trip from south Texas to the mountains of S. California.
I'm looking for CB antenna mounting suggestions on the Prism's MBenz Sprinter chassis.
Ideas?
Dennise is offline   Reply With Quote
Old 03-12-2015, 06:08 AM   #2
hammer55's Avatar
welcome
Not having an answer for your question, wanted to say
Mark & Annie
2014 COACHMAN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-12-2015, 07:06 AM   #3
Former Full Timer
Duckogram's Avatar
Most Sprinter chassis folks I have seen around that have "Radio" plates (Hamsters) had the sticks mounted on the rear ladder with tube clamps.
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 03-22-2015, 07:17 PM   #4
Cool
Thanks, I'll look into that, but just what is a "radio plate"?
Old 03-22-2015, 09:20 PM   #5
Former Full Timer
Duckogram's Avatar
Here in FL its this: http://www.flhsmv.gov/dmv/forms/btr/83041.pdf
and it looks like:
In CA it just has your Amateur Radio License number.
Elbert Hubbard
Old 03-24-2015, 06:27 PM   #6
Cool
Thanks Duckogram,
By "plate" I thought you were referring to some kind of antenna mounting plate. License plate never entered my mind, even though you mentioned "hamsters" ...... and I'm even a hamster myself! Duh ....
Old 07-19-2016, 06:27 PM   #7
Hi, I'm new too Welcome !! I have used several types of CB antennas on prior Sprinter based rigs, !. Glass mounted (window over bunk) 2. Magnetic mount to front cowling area. 3. Metal bracket attached to under hood bolt.
All those worked ok depending on antenna base type, and eliminated any drilling into the body..most antennas work best with a metal ground.
NvBanjofan is offline   Reply With Quote
Old 07-24-2016, 07:21 PM   #8
Former Full Timer
Duckogram's Avatar
NVBanjofan welcome to the forum. FYI: It is usually a waste of electrons posting a response to a thread that is almost a year and a half old. Did you not get a warning notice?
Elbert Hubbard
antenna, coachmen
