Old 09-11-2014, 06:16 AM   #1
Concord outside step addition
I have a 2013 Concord 22LE and it has no outside step I would like to add an outside step as the inside step is high. Has anyone done this modification and any suggestions would be greatly appreciated. Thanks in advance
larryhobby is offline   Reply With Quote
Old 09-11-2014, 06:32 AM   #2
For our sunseeker we bought a portable adjustable step from cw I would be concerned with ground clearance of an outside step.
lbrunning is offline   Reply With Quote
Old 09-11-2014, 06:56 AM   #3
grumpy0374's Avatar
I added a Stromberg-Carlson folding step to my Lexington, for the same reason as you---too high an entry step. Mine worked out perfectly, and was very easy to add.
You can find the info and photo's of mine in the Lexington forum, June 13 2014 posting.
Not knowing your exact set up, don't know if this will work, but it gives you an idea'
Grumpy
grumpy0374 is offline   Reply With Quote
Old 09-12-2014, 06:53 AM   #4
Former Full Timer
Duckogram's Avatar
Here is a link to Grumpy###'s post:
Added a Folding Step, Lexi 283ts
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
