Originally Posted by jegstrup
The only thing I know of that was on was a small LED brake controller
My wife had a habit of leaving the glove box open on her car and the "courtesy light" inside would drain the battery. She didn't drive the car much.
The LED on the brake controller won't drain a healthy battery in a short time. Might be an issue over several months. LED's draw less than some electric clocks.
Check all the switches that can operate accessories when the key is off.
If a diode is "shorted" in the alternator it too can deplete a battery. Worth checking and almost every auto parts store will check for free. Not a major task at all.
Then again, bad batteries can go dead all on their own even if they are relatively new.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
