Old 09-04-2018, 09:41 PM   #1
Hank
Digital tire pressure gauges
Looking to buy a digital tire pressure gauge. Would like some feedback from some of you as to what you have found to work for you.
Hank
Henry Barnes is offline   Reply With Quote
Old 09-04-2018, 10:04 PM   #2
Pressure
Hello, I bought this one almost five years ago. https://www.amazon.com/Accutire-MS-4.../dp/B00080QHMM It's still accurate according to checking with my standard pressure gauge. I did have to put new batteries in it about a year ago. It works great on my class A,
JoePK is offline   Reply With Quote
Old 09-04-2018, 10:37 PM   #3
I am curious why you you would want a digital tire pressure gauge. A good analog one is likely more accurate and you don't have to worry about batteries.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 09-04-2018, 10:50 PM   #4
My experience has been the opposite. Analog devices like a pressure gauge rely on mechanical parts which wear. Digital not so.
That said, don't settle for a cheap "buck ninety eight' digital gauge. get one that at lest has a calibration and accuracy claim. Good ones are available for less than $20.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-04-2018, 10:51 PM   #5
DavidBo's Avatar
I got the same unit after a good bit of research. I too always went the analog route as I considered them more durable and accurate over time, but this thing made me a convert. Easy to use and consistently accurate, worth every penny.
DavidBo is offline   Reply With Quote
Old 09-04-2018, 11:02 PM   #6
Not a newbie
Johnfort's Avatar
Same for me. I bought 4, 2 for a friend, 2 for me. Comparison checked all 4 several times with exactly the same results. Put 1 one the TT and 1 in the TV.
Johnfort is offline   Reply With Quote
Old 09-04-2018, 11:24 PM   #7
Sparkz's Avatar
This one seems to have the best ratings on Amazon and it's just under $10
So far it's been working very well for me.
https://www.amazon.com/AstroAI-Digit...re+gauge&psc=1
2018 Rockwood 2104S
2018 Dodge Ram 1500
Sparkz is offline   Reply With Quote
Old 09-04-2018, 11:28 PM   #8
You must use your pressure gauges a lot if you are wearing them out!
Old 09-05-2018, 12:54 PM   #9
I bought the Milton ExelAir and the 'pip' in the end that depresses the valve core broke off after just a couple of uses. I was past the Amazon return window so I emailed the manufacturer but never got a reply. Not recommended.
Keith & Beth
2018 Isata 3 24FW
Nights camped: 2018: 10
Prior to 2018: Zero
ketchukf is offline   Reply With Quote
Old 09-05-2018, 12:58 PM   #10
Yep, I agree analog wear out, 8 tires, 4 on RV & 4 on TV, once a month min as suggested for best performance and tire wear, also when outside temp change. Adds up!
cruisin
cruisinhwy66 is online now   Reply With Quote
pressure, tire
