11-15-2017, 04:05 PM
Dometic thermostat
Has anyone had a problem with the digital dometic thermostats mine acts a little strange. When I ran a/c the fan kicked on and off a bunch turned everything thing off and back on seemed to work correctly.
11-15-2017, 04:06 PM
Auto text got me again.....dometic
11-15-2017, 04:59 PM
Short cycling is not normally caused by the stat. usually its caused by a dirty air filter (restricted air flow), low refrigerant, Iced over coils or a bad control board. Check the easy things first. Let the forum know what you find
Retired Navy
2016 Flagstaff 26 FKWS
11-15-2017, 05:23 PM
What thermostat do you have?
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
11-15-2017, 05:26 PM
One of the modes of operation of those thermostats is that they will shut down the fan when switching speeds when in Auto.
They automatically switch fan speeds when the temp is either getting close to set-point or moving away from set-point. If your unit was hovering around set-point a few degrees the unit could have been switching fan speeds pretty regularly.
You'll normally hear the compressor remain running, but the fan will stop a few seconds and switch speeds.
Gotta go campin!
11-17-2017, 12:07 PM
Jonwisconson it's the middle model number
11-17-2017, 12:08 PM
Sorry didn't mean to send it two times.
11-17-2017, 12:10 PM
Thanks for the reply I'll keep you updated
11-17-2017, 06:16 PM
Mine does something similar when the temp I choose is easy to accomplish by the a/c. So, I would try to set it up at a lower temp to see if it makes any difference. I had a FW and now a MH with these kind of thermostat. They are more tricky than the old simple ones. Actually, my unit has two different ones since it has two separate furnaces. The one that only handles the bedroom furnace, which the non-digital one is easier to operate.
11-19-2017, 06:20 PM
World Wide Wanderer
This is what it is doing. I have the same thermostat in my Concord and it does it on occasion. Another thing you can try is to reset the thermostat. It is in the manual somewhere on how to initialize it.
Something I have noted is that the internal thermometer on it is not all that accurate. We have to set our A/C temps a bit lower than normal and our heat temps a bit warmer than what we would at home to get things to level out properly. I use a stand along thermometer to keep track of what is comfortable, then adjust the thermostat accordingly.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
12-02-2017, 07:27 AM
We have this same issue. Cycling sometimes off and on within a couple minutes... super annoying. Our only fix is to bring the temp ask way up or down and that usually seems to shake the looping effect off. But if someone else has a better suggestion; great!
Ps- in our coach documentation for the dometic thermostat we got a single post card size page of instructions. Nothing about how to reset the thermostat.
12-02-2017, 07:29 AM
Originally Posted by dongina
Could you post this manual? It looks more fulsome than the one we got. Thanks.
12-02-2017, 02:00 PM
I am not sure what you are asking for, please clarify it for me to be able to help you. Mine is different. However, if I would have yours, I would look at these links for help
http://www.gulfstreamcoach.com/media...tat-Manual.pdf
Please let me know if these help. If you clarify what you are asking from me, I would be glad to help you.
12-04-2017, 11:21 AM
Thanks jonwisconsin. The links you provided took me to a short video of the model I have. It’s a dometic single zone 3 button heat and cooling thermostat. Don’t have the manual but maybe that model only comes with a one page leaflet.
12-04-2017, 06:27 PM
Here's the Dometic Single Zone LCD Thermostat Manual Look on page 3 and there's the instructions for initializing the unit.
Gotta go campin!
12-09-2017, 01:52 AM
Thank you!
