Old 09-26-2016, 11:15 AM   #1
Drag Wheels
What type of drag wheels are you folks using on your Concords ?
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 09-28-2016, 02:27 PM   #2
Wheels
Since I got no response from you guys I took it upon myself to pick drag wheels.. If they don't work out I will be assigning blame here !!!!!!
Old 09-28-2016, 03:29 PM   #3
WDW
What's a drag wheel?
Life is always better under a Palm tree...
2016 Mirada 35BH "Trolley"
2016 Jeep Cherokee Latitude
Previous- Jayco Greyhawk 31FK
Western NY
WDW is offline   Reply With Quote
Old 09-28-2016, 03:48 PM   #4
gwj123's Avatar
I think those are wheels you can have added to the back of your RV to prevent the backend from dragging when you enter or exit something like a steep driveway to a flatter surface.
I am in-process of having them installed on my RV as the backend drags when I enter or exit my driveway, I have already bent those v-shaped brackets that came factory installed for dragging. They are to protect things like your bumper, stabilizers, plumbing, anything that could get damaged if the backend was to drag.
2016 RAM Laramie 2500 CC 4x4 Cummins Turbo Diesel
2017 Forest River Wildwood X-Lite 254RLXL
gwj123 is offline   Reply With Quote
Old 09-28-2016, 04:02 PM   #5
How do they prevent dragging? If the angle is too steep, the rear end is going to drag. A wheel just makes the gap smaller and drags sooner. Whatever the drag wheels are mounted to are gonna take a beating.
325BH is offline   Reply With Quote
Old 09-28-2016, 04:08 PM   #6
BamaBob's Avatar
They are actually called Skid Wheels. They are solid metal wheels usually installed on trailers.
Given how high a Motorhome rides, I could never imagine needing these. In fact if you do need these, I would think you are doing it wrong
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is online now   Reply With Quote
Old 09-29-2016, 12:27 PM   #7
World Wide Wanderer
wahoonc's Avatar
We have some sort of skid back there now, I think to protect the dump lines. I am not a real fan of skid wheels, I have seen some serious frame damage due to the point loading. However they may work in some cases.
I have not seen a need for them on my Concord yet, and have been in some tight areas.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 09-29-2016, 02:51 PM   #8
I know this is in the MoHo section, but...
We had dragging issues with our Rockwood TT and our sloped driveway - I briefly considered "drag wheels" but dismissed the idea due to the stress it would cause on the frame. Our solution was a 3" lift between the axles and frame.
Probably not viable for a motorhome, but perhaps food for thought.
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
www.restcure.ca
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 09-29-2016, 09:37 PM   #9
wheel
I didn't need them on my class A,but this Concord is a C and rides lower..
Old 09-29-2016, 09:49 PM   #10
Land of the Midnightsun
jjSpeedwagon's Avatar
The longer the hang over behind your rear wheels the easier it is to drag. I've drug a jack a time or 2 but I can see it coming so slow is best. You'll be ok. I always try to pull out of any driveways at angle
John & Janice
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
wheel
